speedometer, Pointer removal |
Petepat |
Aug 31 2023, 08:19 AM
Member Group: Members Posts: 60 Joined: 1-December 19 From: Florida Member No.: 23,691 Region Association: None |
So I've got my speedometer out of my 72 914 and have opened it up. I need to get the needle off to get the faceplate off to fix the thing, the problem is trying to remove the needle, it's stuck solid or is there a simple way to remove it I don't know of? All suggestions welcomed.
dr914@autoatlanta.com |
Aug 31 2023, 09:23 AM
914 Guru Group: Members Posts: 7,868 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
send it to Hartmut at palo alto speedometer
So I've got my speedometer out of my 72 914 and have opened it up. I need to get the needle off to get the faceplate off to fix the thing, the problem is trying to remove the needle, it's stuck solid or is there a simple way to remove it I don't know of? All suggestions welcomed. |
87m491 |
Aug 31 2023, 12:24 PM
Member Group: Members Posts: 274 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
Generally it is a twist and pull for the older analog dials of this type. Of course you also have to immobilze the speedo shaft to affect this.
914Sixer |
Aug 31 2023, 02:20 PM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Take small salad fork and lift up
ClayPerrine |
Aug 31 2023, 02:54 PM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Pry upward with a plastic trim removal tool.
The plastic will keep you from marring the front face of the gauge. |
Petepat |
Sep 1 2023, 06:39 AM
Thanks guys the salads fork did the trick!
Lo-Fi Version | Time is now: 22nd May 2024 - 10:56 AM |
