| burton73 |
Sep 20 2023, 01:33 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,994 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
Well, my original 914-6 Engen case for #41 the 30 car off assembly line was found by Glenn Stazak who messaged me that Henry at Supertec Performance had my case. I have been looking for this case since 2007—Henry is Beed blasting it and delivering it to me. It was set up for a 2.5 SS same as the 69 S Eng. that was in the car when I bought it.
My buddy Alan S. says I found the golden ticket! I will not put it in my car but use it as a table in office just in case, on the case. I guess you can never give up on looking. Best Bob B Burton A list of cases that Henry still has for 914-6 914-6 914-6 blank 901/38 640 5596 90mm 901/38 6405156 Message to me from Glenn: Bob, I believe Henry has your original engine type 901/38 number 6404016 list of cases 911 Vintage Parts 760-731-4911 131 N. Vine Street Fallbrook, CA. 92028 Regards, Glenn Stazak ![]() |
| rgalla9146 |
Sep 23 2023, 08:10 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,954 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Those early aluminum chain housings have value. I know of a modified 6 (3.something, flares etc, etc.) and the location of the original block. The car owner is not interested... even for cheap money. Go figuire. Congratulations Bob ! Good job Glenn ! |
| burton73 |
Sep 23 2023, 09:06 PM
Those early aluminum chain housings have value. I know of a modified 6 (3.something, flares etc, etc.) and the location of the original block. The car owner is not interested... even for cheap money. Go figuire. Congratulations Bob ! Good job Glenn ! ------This is the info from the Ebay ad when I got the car, Dec.27th 2006 --------- Hi Lloyd -- (the very nice guy I bought my car from— This is a great project car for the right person. I bought it in 1980, and stopped driving it when it couldn't pass smog. It last ran in 1990 and has been stored under cover in my garage since 1990. Before I owned it, it was a project car of a guy that worked at a local Porsche speed shop. This has always been a California car. It has never seen salt and has no rust.Engine 2.5 L 20k Miles Aluminum case 2.2. Rods EMPI, 88 mm pistons and cylinders, Ported heads and manifolds 40 IDS Weber Carbs, CD ignition, 911S Distributor 67 911S Cams Front 914/6-GT oil cooler with GT ducting, Aeroquip Stainless Steel Lines and oil thermostat, Sport Muffler, Transmission Rebuilt 2000 Miles ago by Performance Haus, 911S copper faced clutch, Hand polished close ratio 906 gears Late model "side shift" linkage, Suspension Adjustable 19mm front sway bar with Teflon bushings Bilstein Carrera RS front struts, adjustable perches, Bilstein rear shocks, Modified front 911S calibers with cross-drilled "S" rotors Five 15x7" BBS modular rims Magnesium centers Titanium lug nuts, 12mm torsion bars. Body Body seams bead welded Fuel filler moved to cowl. Aircraft style cover Side markers removed European front turn assemblies,French tail light lenses Factory Convex RH mirror Quartz Iodide headlights European 911S gages including oil level LeCarrera steering wheel Scheel 914 seat.------- I have had many questions about the fuel filler area. Peter Dawe of Dawe's Motorsports helped build this car at Dick Troutmans's in the late 70s. I asked Petr how this was done, below is his answer. Hi Lloyd From what i can remember the hinge and the flush mount latch was aircraft surplus. I believe all those parts are offered thru Aircraft Spruce Co. Peter welded a shaped piece of steel under the body cowl for the gas door to sit on . He also welded a fill pipe on to the gas tank. (Only for pros to weld) Then because of the pipe bends he had to put a vent from the original fill to the neck so the tank could be filled up to the top. All this was 20 years ago but I think thats about it. But you have to be as talented as Peter to do it right. Thats the TRICK. Thanks and happy holidays Petr Dawe |
burton73 My original 914-6 engine case, will be back with its car. Sep 20 2023, 01:33 PM
VegasRacer Ausgezeichnet. :Qarl: :first: :beer2:
Couldn... Sep 20 2023, 01:41 PM
Couldn... Sep 20 2023, 03:12 PM
infraredcalvin Keeping the hope alive, nice find Bob! Congra... Sep 20 2023, 01:46 PM
SirAndy Nice! :trophy: Sep 20 2023, 02:03 PM
burton73 Henry is selling all his parts on BAT, just a tip... Sep 20 2023, 02:17 PM
Shivers Congratulations, what were the chances of finding ... Sep 20 2023, 02:47 PM
Cairo94507 Congratulations Bob! I am very happy you foun... Sep 20 2023, 03:13 PM
dr914@autoatlanta.com great news congratulations!!
Well, my o... Sep 20 2023, 03:23 PM
DennisV
Well, my original 914-6 Engen case for #41 the 30... Sep 20 2023, 03:25 PM
930cabman How cool is that?? after searching for 16 year... Sep 20 2023, 03:56 PM
Beach914 Great discovery! Congratulations. Is it know h... Sep 20 2023, 05:45 PM
burton73
Great discovery! Congratulations. Is it know ... Sep 20 2023, 06:25 PM
76-914 Congratulations Bob. You must be on Cloud 9. :bee... Sep 20 2023, 06:57 PM
sixnotfour Fantastic Bob..Congrats.. :beer2: Sep 20 2023, 07:04 PM
Jett Amazing! Sep 20 2023, 07:17 PM
technicalninja That's really pretty cool! :beer2:
Bet y... Sep 20 2023, 07:41 PM
markhoward Congrats Bob! What are the odds.. Sep 20 2023, 07:44 PM
tygaboy Wow. So cool! BIG Congrats! :cheer: :tro... Sep 20 2023, 10:05 PM
flyer86d So I guess you can actually find a needle in a hay... Sep 21 2023, 04:04 AM
JmuRiz Great find!
....and I can't believe Henry... Sep 21 2023, 07:08 AM
gms I am so happy that your engine is reunited with th... Sep 21 2023, 08:59 AM
burton73
I am so happy that your engine is reunited with t... Sep 21 2023, 04:27 PM
Root_Werks Holy crap! That's awesome!
Numbers m... Sep 21 2023, 10:09 AM
mepstein Bob - What are you doing with it? Sep 21 2023, 10:12 AM
burton73
Mark,
Going ... Sep 21 2023, 11:08 AM
914 Bob,
Glad you got the Golden Egg..Cant wait the se... Sep 21 2023, 11:50 AM
burton73
Bob,
Glad you got the Golden Egg..Cant wait the s... Sep 21 2023, 12:03 PM
burton73 In life timing is everything. I am really lucky in... Sep 21 2023, 01:01 PM
Eric_Shea Awesome news! Sep 21 2023, 01:13 PM
burton73 Well, the case came today Sept 22nd in perfect sha... Sep 22 2023, 05:06 PM
914 Bob,
So really cool.. Sure looks nice..
914/Alan Sep 23 2023, 08:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th April 2026 - 01:15 PM |
