Oil tank fit, /6 conversion |
930cabman |
Sep 22 2023, 09:22 AM
Advanced Member Group: Members Posts: 3,073 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
How many guys have done the /6 conversion and had the tank cut outs fit correctly with a new tank?
can we "assume" all inner fender stampings are identical, but maybe not? I have two new welded aluminum tanks from different suppliers, neither would fit into the location as supplied. I cut 3/8" from the vent pipe to get one of these into the correct area. Then I proceeded to drill the mounting holes and followed with the hole saws. Once again, I assumed with all of the new penetrations centered in their respective stamped recesses all would be correct. Not, the oil filter console is off center 1/4" and the oil fill stub is offlocation by 3/16" Is this a common issue? One of the vendors when contacted claim "We typically cut all the holes a little large, then float the tank &filter console into place" Sounds hokey to me. |
Lo-Fi Version | Time is now: 22nd May 2024 - 01:01 AM |
