9 Pages V « < 7 8 9
> Project 3.6 RS Thread, Live and learn.. Tires rubbing at Autocross
mskala
post Nov 9 2026, 08:49 AM
Post #161
R
When I was autocrossing my -6 with ~150HP (narrow body), it worked well
with 20mm front torsion bar (Elephant was only one making these) and 180lb
rear springs, no rear sway bar, very soft front sway bar. I used 205/45 on
7.5x16 wheels. As was said, you will need an adjustable brake bias.
If using autocross tires like RE71, the sidewalls are very stiff, and you will need
to keep pressure much lower than you have, probably below 25psi.
Any 914 should be able to be set up to handle trail braking fine. But with the low
weight of these cars, either the front needs to either stay a bit soft or you will
need to initially apply the brakes more gently to get the weight transfer. And,
with high HP, be gentle on the gas on the way out of the turn.
Also, for the lug nuts, I was always under the impression that you should have
as much thread engagement as stud diameter; that would mean
14mm / (1.5mm/thread) = 9.3 turns of engagement for safety. I suspect you
would get flagged at tech sometime if you have a lot less than that.
post Nov 9 2026, 09:20 AM
Post #162
914-6 GT in waiting
open lug nuts makes everything easier
brant
post Nov 9 2026, 11:11 AM
Post #163
QUOTE(mskala @ Nov 9 2026, 07:49 AM) *
9 Pages V « < 7 8 9
- Lo-Fi Version Time is now: 10th November 2026 - 07:04 AM
