Transmission Leak, Output shaft seal |
Stratfink |
Mar 30 2024, 02:59 PM
Newbie Group: Members Posts: 39 Joined: 27-December 21 From: SoCal Member No.: 26,198 Region Association: Southern California |
I've been finding transmission fluid on the garage floor since acquiring the 914 about 18 months ago. Finally got her on the quickjack and cleaned up the caked on gunk last weekend as best I could. after sitting for a week I found a drip at the usual spot on the pulley housing. From the picture it looks appears the source is at the output shaft seal.
Found the thread below with great info/advice and thinking I'll order seals from Stoddard and venture into my first transmission seal repair. http://www.914world.com/bbs2/index.php?showtopic=322114 Am I on the right track or does one of our experts see something else that could be the culprit? Assuming this is the fix on the trans, l'll be looking into the oil leaks next (IMG:style_emoticons/default/smile.gif) |
Cairo94507 |
Apr 1 2024, 08:06 AM
Michael Group: Members Posts: 9,723 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Yeah, the output shaft seal is a pretty common spot for leaks. We have replaced both seals on my transaxle and the driver side is nice and dry now. The passenger side is leaking about a drop when parked. Now that the transaxle is out, we will replace that seal again. Fortunately it is an easy seal to replace- especially with the transaxle out of the car. (IMG:style_emoticons/default/beerchug.gif)
windforfun |
Apr 1 2024, 02:54 PM
Senior Member Group: Members Posts: 1,776 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Sealing surfaces must be spotless. Be very gentle with seal when installing.
Stratfink |
Apr 2 2024, 07:38 AM
Lo-Fi Version | Time is now: 3rd May 2024 - 06:01 AM |
