Need help with minor electrical problem, Radio and wipers |
MoveQik |
Sep 12 2005, 12:00 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
I was screwing around with the wiring on my radio yesterday and heard a snap crackle pop. Now my radio and my wipers don't work. Not sure why. I didn't think they were hooked up on the same fuse. Besides that, I have checked all fuses and everything appears to be good. I checked the fuse panel, none are blown. I replaced one fuse on the stereo as is blew but the other one was fine.
Everything worked before I attempted to "clean up the wiring." Now the wipers and rado are MIA. Any suggestions? Below shows where I hooked the radio into the fuse panel. Any advice is appreciated! Attached image(s) |
MoveQik |
Sep 12 2005, 02:32 PM
Did I ask a question on the day that no one has answers?? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
dbu356 |
Sep 12 2005, 03:07 PM
Member Group: Members Posts: 120 Joined: 2-May 04 From: Scottsdale, AZ Member No.: 2,013 |
It dosen't rain in Scottsdale.......and you don't need no stinkin' radio.
No help here but at least I'm listening. |
MoveQik |
Sep 12 2005, 03:10 PM
I know it doesn't rain here but I would like them working for the RRC. I hear that other parts of the country actually get rain. I gots to be prepared. As for the radio, if I don't get it fixed I am going to be forced into listening to my passenger yap yap yap the whole way to Moab.
lapuwali |
Did you do an continuity test on the "unblown" fuse to make sure? Sometimes they LOOK OK...
MoveQik |
Sep 12 2005, 03:12 PM
After I posted this topic I replaced the fuse just to be safe. Still no dice. |
tdgray |
Sep 12 2005, 03:19 PM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
First things first my good man.
Does the terminal that the stereo wire goes into have juice? On both sides? How about the fuse for the wipers? Got's juice? Pick a point and start... gotta give a little something to go on. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
Flat VW |
Sep 12 2005, 05:39 PM
Illegal Soapbox Derby Racecar Group: Members Posts: 1,692 Joined: 13-November 04 From: Phoenix, AZ Member No.: 3,105 |
Rain-X John (IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif) |
MoveQik |
Sep 12 2005, 05:59 PM
I will get out there tonight and check everywhere I can think to check and report back with the findings. |
MoveQik |
Sep 13 2005, 02:07 PM
Ok....I went out with a test light and this is what I found....for all I know this is the way it should be. The 3 on the right had power on both sides of the fus at all times. The 4th from the right only had power when the ignition is on. All the others had nothing at all times. Does that help you guys trouble shoot my problem? If not, give me some more advice and send me back out there!
lapuwali |
Sep 13 2005, 02:26 PM
That's expected. Red wires carry battery power 100% of the time. Black wires carry switched power. Several of the fuses only have power when the ignition is on. Several of them have power all the time. There's a Pelican article that explains what each fuse does.
tdgray |
Sep 13 2005, 02:31 PM
Well...
Now you know you have power. I believe this is the correct way those fuses should work, double check the pelican article. Next thing to check is the ground on both malfunctioning units. Got's good ground? After that is confirmed start checking related wiring to said components. Have you tried to run a designated "hot wire" to both yet. If not try it. |
MoveQik |
Sep 13 2005, 02:51 PM
Electrical school for dummies...... How do I check for a good ground? |
lapuwali |
Sep 13 2005, 03:37 PM
Brown wires are grounds, so find all of the brown wires coming out of the thing that's not working, and follow them to whereever they connect to the body. Visually inspect things make sure there's no corrosion, and try testing the connection with a meter (ohms setting, make sure you have 0 ohms at the connectors and a body ground point). Note that paint and muck inhibit a good connection. The best thing is to test the connector at the non-working part and another ground for something that does work (like the headlights). If you get 0 ohms between those two points, you have a good ground.
jasons |
Sep 13 2005, 03:52 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
Do you have a voltmeter or just a testlight? With a VoM you can look for continuity from across the ground wire that connects to the radio/wiper motor and the chassis. If you get an open, then your ground is bad. You can also look for something obvious with your eyes, but you have probably done that already. If you haven't, look for a burnt or loose ground point. Since you heard the snap crackle pop, you probably shorted a power to ground and burnt something. It might be evident, you may even smell it. Your circuits might be good, and you might have killed the stereo and the switch for the wiper motor. Basically, I would approach the stereo first because it is easy to access. Pull it out and test the power/ground that go directly to it. If they are good (12v) try to wire it directly to the fuse panel or even the battery (known good 12v and ground) to determine if you smoked the head unit. You can repeat this procedure with the wiper motor. Thats probably more tricky due to the location of it. If you're still not having any luck I might be able to help you out with it tonight if you are interested. |
MoveQik |
Sep 13 2005, 04:10 PM
Ok, so I hooked one wire from the meter to this connector on the wiper assembly and the other wire to a good ground and the meter went to zero. Was this correct? If so, where to check next? Attached image(s) |
94teener |
Member Group: Members Posts: 209 Joined: 6-February 04 From: Jacksonville, FL Member No.: 1,636 |
MW914,
You say you have power on Fuse S8 (Fourth from the right) when the ignition is on but, your radio and wipers don't work? There are three RD/BK wires on the output side of S8. If you have power on both sides of S8 then you should have power on the wipers, the cigarette lighter and the fresh air blower. If your radio (connected at S8) and the wipers don't work, then there is a disconnect in logic (as well as power) somewhere. Recommend you replace the fuse on S8 and carefully recheck for 12 Volts on both sides of S8. Also, check the fresh air blower (center console) and cigarette lighter for 12 Volts when the ignition is on. Let us know what you find. Thanks, Phil |
MoveQik |
Sep 13 2005, 04:12 PM
Thanks for the offer Jason. I have to meet with clients tonight, however.
94teener |
Sep 13 2005, 04:17 PM
The pin you connected to on the wiper motor assembly is "chassis ground". Therefore, you were reading ground to ground, i.e., zero.
Phil |
MoveQik |
Sep 13 2005, 04:26 PM
First of all, thanks to all of you guys for walking me through this. It has all been great info. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) 1 - Now, since I checked the wrong ground on the wiper assembly, where should I have attached to? 2 - My stereo WAS wired to the 5th fuse from the right. So I moved it over to the fourth. Now the stereo works but I have no idea if moving it to that fuse will create any other problems. Anyone? 3 - Stereo working is good...but still no wipers. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) |
Lo-Fi Version | Time is now: 2nd May 2024 - 03:29 AM |
