| bug man nrg |
Sep 17 2005, 07:05 AM
Member ![]() ![]() Group: Members Posts: 66 Joined: 17-September 05 From: florida Member No.: 4,811 |
what is the right price for a full efi set up for your type4
ECU TB'S SENSORS 8 FOOT OPEN END LOOM INJECTORS FUEL PUMP AIR FILTER we were told that it cost is to high to up grade to a stand alone 32 bitt ECU and all the parts to go with it .We would like some feed back to see if we can fix this miff www.emeraldperformance.com |
| rhodyguy |
Sep 17 2005, 07:23 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
welcome to the club bug man. many folks have been waiting for an update and pricing on your fuel injection system. tell us what you need the package to retail for, and you'll get feedback. you may remember me.
kevin powers (big K) |
| JeffBowlsby |
Sep 17 2005, 09:33 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,246 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Most 914 owners simply swapping their current D-Jet for a new system, for stock or nearly stock 914s, need it to be bolt on and drive. So we really dont need TBs, sensors, injectors, fuel pump or an air filter, we have these already and can get stock parts rather than having to buy or adapt GM parts or anything ported over from some other platform. These can add up to huge $$$, and unecessarily. What we need is a preprogrammed ECU, with wiring harness prefit to or easily adapatable to our engines, and thats it. If its absolutely essential to swap sensors (if the ECU maps cannot be changed for instance), then I guess that can be done, but less hassle and the fewer mods we need to make, for us is better. A programmable ECU would be best for the cars with modifications, but they should be preprogrammed for stock 1.7, 1.8 and 2.0L requirements out of the box, or come with the maps for the user to program as long as programming is not to difficult. Most of us don't need 50-gazillion options for ignition control, turbos, etc....there are other systems for those folks already. Price? Sub 1K would be very nice and should sell well for the basic system described. The higher you get above 1K to convert to some other system, the more unreasonable it becomes. |
| JeffBowlsby |
Sep 17 2005, 11:37 AM
I just remembered, the TPS may be the one sensor we need to swap, becasue of the type TPS our cars come with and that they are becoming expensive and hard to find. The 1.7 and 1.8 cars TPS are NLA.
So figure to replace the TPS with a resistor type TPS. |
| bug man nrg |
Sep 17 2005, 06:17 PM
we have done the 914 with the stock sensor's .If you just need a ECU and a loom we can do this .we also have done a up grade to the stock plenum with a 65mm tb and tps and 23lb injector's in 2.0 runners and there is a progessive set up with the tb from a vw golf that is fitted to the stock plenum .if you check the web site www.emeraldperformance.com there is a lot of info on how EFI work on the info page my car is also on this site under project cars a 2054 turbo efi
ECU coms loom injector's maps manual $1375 + shipping Are you a shop if so i will need your tax ID if you are in florida |
| redshift |
Sep 17 2005, 06:59 PM
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
ROFL! WOW!
M |
| Brando |
Sep 17 2005, 10:31 PM
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
$1375 for injection system alone?!
I don't think EFI systems will sell too well for our older cars until they are price-competetive with carbs! |
| DBCooper |
Sep 18 2005, 06:24 AM
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
Have you priced a new set of Webers lately? A 40 IDF kit with Brasilian carburetors is $1000 from CB, so that price isn't out of the ballpark, especially given the improvements you get with injection. And Emerald has a good reputation in the Lotus Seven world, by the way. I don't have personal experience, but several of the U.K. performance parts distributors/tuners sell it and it gets good reviews for value/performance.
| Mark Henry |
Sep 18 2005, 08:10 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Does that price include the sensors (TPS, head temp, MPS, etc)?
Yep price new carbs...EFI is getting right in the ballpark but unless you are offering a BOLT on pre-programmed system most other systems are comparable. Also any maps other than bone stock on a fresh engine is no more than a baseline. Add 2.0, 1.8, 1.7., high performance and even just wear into the mix and your maps will need changing. Not to mention that a large number of 914 owners are CSOB's (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
| lapuwali |
Sep 18 2005, 10:07 AM
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
The price of even new carbs are likely to fall soon-ish, as cheap Chinese made knockoffs are appearing. Used carbs with a rebuild kit are, IMHO, just as servicable, and the price of these are still pretty low. $250 for a set of carbs, $400 if it includes filters, linkage, manifolds.
$1400 is pretty much in line with a lot of other EFI ECUs. SDS is about that much once you get all the extras and sensors. MS is a lot cheaper, about $300 for a pre-built ECU, but you have to do more work yourself. Figure $500 by the time you have everything you really need to swap to it (assuming you have a D-Jet setup you can use for TB, manifolds, injectors, etc). |
| bug man nrg |
Sep 18 2005, 07:02 PM
this set up come with full running maps from cars that have been on the dyno they are not base maps .you will have to fine tune them to fit your engine spec ie if you have a type4 with 450cc injector's and the map is set up for 310's you will have to trim fuel so it will not run fat .No two engine are the same but it would be in the ball park
it will work with your OEM sensors |
| Brando |
Sep 18 2005, 07:31 PM
bug man, what kind of options would we have for custom programming? Say for engines geared for top-end with wild cams and such? We'd pretty much just need a dyno and some -- special software? EPROM reader/writer? USB + laptop???
| bug man nrg |
Sep 18 2005, 07:58 PM
You have full control on timming and fuel air temp coolant temp map sensor and so on .YOU HAVE 100% CONTROL OF THE ENGINE for turbo or NA engine (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) have you looked at the web site i have a full brake down on how it all work's on the info page and the spec's on the ECU www.emeraldperformance.com and we have a FREE demo and manual in the down loads (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
| rhodyguy |
Sep 19 2005, 06:46 AM
would we be buying directly from you or would we have to deal with steve stromberg?
k |
| bug man nrg |
Sep 19 2005, 06:07 PM
You can get it from me or you can get it from steve .why? it is up to you . (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
| DNHunt |
Sep 19 2005, 07:04 PM
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Bug Man
Steve Stromberg's reputation here is a bit tarnished as in a pile of (IMG:http://www.914world.com/bbs2/html/emoticons/stromberg.gif). Check out the label on that clickable smile. We have reason to suspect his business practices. Dave |
| TimT |
Sep 19 2005, 07:09 PM
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
We sell Haltech E6x systems for $!284 with a base map, sensors, and a flying lead kit, the map sensor and pickup config are additional.... since there are many possibilities with those
seemed like an appropriate thread for a shameless plug LOL |
| Mueller |
Sep 19 2005, 07:51 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
what many of us are looking for is a plug-n-play solution to replace the stock FI electronics and controls....
not everyone needs or wants individual throttle bodies, it just drives up the cost..make it an add on option I think you'll get more response with just the "basics"....an ECU with a pre-programmed MAP, a near-bolt on/plug in wiring harness and the needed sensors...... I ended up going with the LINK due to price since it was a few hundred less than the Haltech, if I was to do it again, I think I'd go with the Haltech due to more support..mind you the support for the LINK is not bad, it's just that there are more Haltech people in my area and more support on the web for them. |
| bug man nrg |
Sep 20 2005, 01:21 PM
we are workimg on a new loom for the 914 so it would be a plug an play the old loom in the car is aged and has problem's with parts of it being brittle
we are looking for a 914 in florida where we can run the new loom and a upgrade to the efi set up at a discount price to the owner (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) www.emeraldperformance.com |
| qa1142 |
Sep 20 2005, 04:21 PM
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
I am game but in Chicago area. Are yo doing D Jet or L jet or both?
Lo-Fi Version | Time is now: 1st May 2026 - 12:18 AM |
