lowered spindles, shady grady & Jason style |
sean_v8_914 |
Sep 17 2005, 10:12 PM
this solves 2 of my problems
1 I want to use my konis 2 I want to lower my ride height the right way Jason at Prestige Motors just showed me this(and the entire PCA-SDR) 2 nights ago as a way to drop the ride height without adversly changing the suspension geometry. I posted a FS/trade ad here to try to trade my Konis for Bilsteins and shadygrady has shown me this as a solution to use my Konis with teh 930 spindles I am so glad 914clubers were here to club me over the head with the obvious solution to both problems. I hope this will benefit others. this is the easiest and most mechanically correct method ???how do I grind out the weld without a mill? how Attached thumbnail(s) |
sean_v8_914 |
xcgfdx
sean_v8_914 |
Sep 17 2005, 10:13 PM
xcgghc,
sean_v8_914 |
uho8y
Aaron Cox |
Sep 17 2005, 10:15 PM
one can only go so far before the wheel hits the a arm...
how much did you raise them? looks bitchin (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) you can also bend UP the pitman arm to compensate even more... |
sean_v8_914 |
Sep 17 2005, 10:17 PM
I will drop mine one inch only
sean_v8_914 |
Sep 17 2005, 10:18 PM
THANKS GRADY! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
914werke |
Sep 17 2005, 11:00 PM
"I got blisters on me fingers" Group: Members Posts: 10,100 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
So Sean, more details. Are those 911 or 914 strut housing tubes? The spindal section appears to be off a 911..3.5"spacing and M calipers? How did you cut the stock weld? A Mill? How much did the process cost?
brer |
Sep 17 2005, 11:24 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
put the whole strut assembly on a lathe and cut the welds, as i've been told.
I just looked at a car today that had this done. The 911 RSR had about 17-18mm, but if you are running 16s or 17s you can go as much as 30mm before hitting the rim. Another modification this fellow did was to cut the A arm and lengthen it 5/8" on each side. when i get some links i'll post them. |
sean_v8_914 |
Sep 18 2005, 01:59 AM
shadygrady did the ones in teh picture
the tubes are 914/4 koni the spindles are 911 that were removed from Bilstein 911 strut tubes teh factory weld was under the circular re-weld shown in teh pic Jason from Prestige used a mill to mill out the factory round weld |
TimT |
Sep 18 2005, 06:05 AM
if you dont have a mill, use a hole saw. We drillout he rosette weld by holding the strut in a vise and using a drill press and hole saw to drill the weld out.
We then raise the spindle, reweld the rosette, and add some gussets to reinforce the strut |
sean_v8_914 |
Sep 18 2005, 09:40 AM
what do you gusset? what is teh weak part that requires gussets?
Verruckt |
Sep 18 2005, 12:34 PM
Senior Member Group: Members Posts: 716 Joined: 14-July 04 From: Midwest Member No.: 2,348 |
Nobody has mentioned this yet, but a fellow club member already does this modification and sells it..
(IMG:http://www.tangerineracing.com/images/Suspension&Brakes/FrontStrutMod.JPG) http://www.tangerineracing.com/Suspension.htm This is the route I'm going to take. Also sells a nice way to lower the ass too. |
ArtechnikA |
Sep 22 2005, 05:57 AM
if it's a factor, be sure to check your competition rules.
in many cases, any suspension change that requires welding or machining will move you directly to Modified, do not pass 'Go' do not collect $200... |
sean_v8_914 |
Sep 22 2005, 10:35 AM
I will be doing this on my V8 car, not the 2.0 CS class runner
J P Stein |
Sep 22 2005, 10:46 AM
Note the joggled pitman arm in the pics of Chris' work.
Don't forget that part. I have a set of raised spildles waiting till I figure how in hell to do that bit here at home......more tools $$$ There is a hella expensive kit from Smart Racing that will do it for ya, but I'm not comfortable with it's stamina (there's a obtuse statement for ya (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) ) I got the parts from a guy that balled up his race car.....with no provisions for this feature.....go figure. |
Brett W |
Sep 22 2005, 11:49 AM
You can't take the stock 914-4 spindles and cut the weld to slide it up. The four cylinder strut tubes are tapered to keep this from happening. You need to section and re-weld thetubes to shorten the four cylinder ones.
Lo-Fi Version | Time is now: 26th May 2024 - 07:02 AM |
