Can you tighten a factory side mirror?, Mine won't stay put! |
MoveQik |
Dec 6 2005, 11:53 AM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
Every time I get off the freeway, I have to adjust my side mirror as the wind pushes it up, down, in...everywhere. Is there a way to tighten the thing up?
Joe Ricard |
Dec 6 2005, 12:36 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Oh the other nut. Yea that one is a real PITA
The mirror glass has to come out. To do this usually means destroying the brittle rubber glass surround when removing it. once the glass is out then the same "tighten the nut" procedure. |
Cuda911 |
Nov 20 2017, 02:06 AM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
Oh the other nut. Yea that one is a real PITA The mirror glass has to come out. To do this usually means destroying the brittle rubber glass surround when removing it. once the glass is out then the same "tighten the nut" procedure. Rather than destroying the rubber, if the rubber ring doesn't pop out, just break the glass out and get some new glass cut. Cheap and easy. Worked for me. Of course, you can also just order some '73 Mustang mirrors as replacements. My understanding is that most here prefer them to the stock mirror. Attached image(s) |
Valy |
Nov 20 2017, 09:50 AM
Senior Member Group: Members Posts: 1,673 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Oh the other nut. Yea that one is a real PITA The mirror glass has to come out. To do this usually means destroying the brittle rubber glass surround when removing it. once the glass is out then the same "tighten the nut" procedure. Rather than destroying the rubber, if the rubber ring doesn't pop out, just break the glass out and get some new glass cut. Cheap and easy. Worked for me. Of course, you can also just order some '73 Mustang mirrors as replacements. My understanding is that most here prefer them to the stock mirror. Can you please post the specific pattern to brake the mirror? (IMG:style_emoticons/default/lol-2.gif) |
