| Lou W |
Jan 16 2006, 07:06 PM
"Here Kitty Kitty" my ass...... ![]() ![]() ![]() ![]() Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
Rear trunk;
| Lou W |
Jan 16 2006, 07:07 PM
Next, I will shoot a couple more thinned down coats of primer;
| Lou W |
Then, I'll finsh with 500 grit, before applying the sealer;
| Lou W |
Jan 16 2006, 07:08 PM
Then , finally a finished color, Yahoo, I'm getting close. (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
| Lou W |
Jan 16 2006, 07:10 PM
I started cleaning the latched and catches, I used this, I let the parts soak for about an hour, then I scrubbed them with a parts brush, and rinsed them off and applied light oil to prevent rusting. It really worked well;
| Lou W |
Jan 16 2006, 07:12 PM
I bought Engmans Stainless Steel Door Straps, and new rollers from Performance Products, the original ones were in pretty rough shape. The rollers arrived today, so I installed the parts;
| Lou W |
Jan 16 2006, 07:13 PM
They cleaned up pretty good;
| Eric_Shea |
Jan 16 2006, 07:15 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Lou, Lou, Lou, Lou, Lou, Lou, Lou, Lou, Lou, Lou, Lou, Lou... (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
| jim_hoyland |
Jan 16 2006, 07:17 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,957 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Sweeeeeeeeeeeeeeeeeeeet !
| seanery |
Jan 16 2006, 07:21 PM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
this looks great! (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif)
| Lou W |
Jan 16 2006, 07:24 PM
After taking the door strap assembly apart, and seen how worn down the strap and cracked the rollers were, I would strongly recomend that you take yours out and repair them. My drivers side brackets roller pin had elongated the mounting hole in the bracket itself, so I will most likely have to replace that one. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
| craig downs |
Jan 16 2006, 10:43 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 769 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
Hey Lou
If you shoot what they call a guide coat over the primer before you sand it it makes sanding alot easyer. Its just a fine mist like overspray of a contrasting color like in your case black. Then do your final block sanding. When you sand all the guide coat off you're done and it will be nice smooth and flat. Also the guide coat will show all the low spots and scratches if any. Looking real nice Craig |
| Lou W |
Jan 16 2006, 11:08 PM
Craig,
Thanks for the input, that would have been the smart thing to do. I had considered doing that, but I was really focusing on the orange peel as my guide. when I do the deck lids and the doors, I will definately shoot a Guide Coat. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
| Lou W |
Jan 23 2006, 12:05 AM
I started to work on the rocker panels that I bought from Dave (Korijo). First I stripped them with paint remover;
| Lou W |
Jan 23 2006, 12:06 AM
another;
| Lou W |
Jan 23 2006, 12:07 AM
I had to do a little bit of fiberglassing;
| Lou W |
Jan 23 2006, 12:09 AM
I filled in the holes for the jack posts, I'm planning on using a scissor jack;
| Lou W |
Jan 23 2006, 12:12 AM
I shot the final coat of primer last week, so now I'm block sanding again. I started off with 500 grit, I found it would hardly cut the primer, so I read the instructions (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) and, it said use 320 to 400 grit, so I'm using 360 grit instead and its making a big difference. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) ;
| Lou W |
Jan 23 2006, 12:13 AM
Here's a better picture;
| Lou W |
Close up;
Lo-Fi Version | Time is now: 11th December 2025 - 10:34 AM |
