6 Pages V « < 3 4 5 6 >
> Carbs on a completely stock 2.0L, does it work
seanery
post Jan 4 2006, 08:10 AM
Post #81
waiting to rebuild whitey!
If there is a CR difference of 1.3 between a factory carbed car and a FI one then there is more than just an intake and a pair of carbs difference.
r_towle
post Jan 4 2006, 09:28 AM
Post #82
Custom Member
up until recently, Jake used only carbs on his motors..
Now that he has found a good FI system that he can tune, he loves FI...
I think that SirAndy hit the nail on the head...
Modern cars use FI because it is more precise and can be specifically tuned for each motor...
Djet/Ljet are purpose built and specifically tuned for these motors...no VE changes are acceptable..
Carbs offer some tuning options that you cannot get from djet/ljet.
Though there are less and less proffesionals that can tune dual webers correctly, there are lots more of them that can tune a PEFI system perfectly...
So, do you do your own work, or do you bring it somewhere to have it tuned?
If you like to play, carbs are for you.
I put dual 40mm carbs on a 1600 vw motor...it took some time, I worked with the great guys at aircooled.net and the car now runs as good as its gonna...
You really need to warm it up, and the MPG suffers on such a small motor..
But, that is what the kid wanted, he likes dual carbs, he loves the sound...
Now with the prices of fuel, he wants a FI system...
I would say if you have a working FI system, dont change...if you have working carbs or a desire for carbs, go for it...they are fun, they are easy to tune if you get the basic concepts down...
Just err on the small side for jets and venturis and you will be alot happier...smaller venturis help alot more than you would think..
Rich
Gearhead1432
post Jan 4 2006, 06:37 PM
Post #83
The only specs I can find for any 914 cam happens to be the valve timing, which is listed as being the same for all 914 type4s. If any one happens to have better data, by all mean.
Intake opens @ 12* BTDC
Intake closes @ 42* ABDC
Exhaust opens @ 43* BBDC
Exhaust closes @ 4* ATDC
billd
post Jan 4 2006, 06:53 PM
Post #84
Dan,
I know that Albert's 2.0L was *not* running a stock cam. I'm not sure about his 1.8. Albert told me he was running a webcam in the 2.0. He did not tell me which grind.
When I was looking at cams for a carbed 4, I came to the conclusion that a webcam 86b/163 was the cam of choice for autocross (good low-end torque, sacrifice some at the top) and an 86c was the cam of choice for TT (less at the low end, more at the top).
----Bill
Trekkor
post Jan 5 2006, 07:31 PM
Post #85
I do things...
I'm surprised no one has the cam answer...
All these guru's, pros and builders and nothing? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Should be pretty simple. Do they all use the same cam or don't they?
KT
post Jan 5 2006, 07:38 PM
Post #86
Resident German
QUOTE (trekkor @ Jan 5 2006, 05:31 PM)
that's probably because all the "gurus" have stopped reading this thread a month ago ...
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Andy
Trekkor
post Jan 5 2006, 07:41 PM
Post #87
I do things...
It may be one of life's great mysteries (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif)
KT
r_towle
post Jan 5 2006, 07:53 PM
Post #88
Custom Member
QUOTE (trekkor @ Jan 5 2006, 08:31 PM)
KT
you are stepping into an area that the proffesionals make a living at.
The heads and valve train are where the power is on these motors, and as we have all seen, if you have the valves adjusted correctly, your car runs perfect.
I would say that there are alot of answers to the same problem...
I was reading the ecellence article about an orange 914 with a 2.7 liter /4 that made similar HP and torque to a 2270
All in the heads...bore and stroke are pretty straight forward, but you are asking the same question here that has been asked before and on lots of boards....
If you would like a good answer, I would suggest that you purchase a valve train setup from Jake, you will learn your answer then...
Or, buy several grinds and try a few...
Rich
DanT
post Jan 5 2006, 07:58 PM
Post #89
Going back to the Dark Side!
That was not the question.
The question was do factory carb equipped car use the same cam as the EFI cars. If in fact the factory had a carb option.
Aaron Cox
post Jan 5 2006, 07:59 PM
Post #90
Professional Lawn Dart
QUOTE (Dan (Almaden Valley) @ Jan 5 2006, 06:58 PM)
want it EURO 1.8's had dual solexes? single or dual barrel 40's iirc....
Trekkor
post Jan 5 2006, 08:16 PM
Post #91
I do things...
I'm not asking for trade secrets. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Just looking for a simple answer.
In the Performance Products catalog you can buy a new stock cam, 70-76 ( no specs given )
If you order an aftermarket grind, the specs are front and center (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
KT
McMark
post Jan 5 2006, 09:59 PM
Post #92
914 Freak!
Tuna's site says that the euro AN case 1.8 come with dual 40s and made 85 hp compared to a US 1.8 with 76 hp, BUT the euro model has 8.6:1 compression and the US model has 7.3:1.
Read that however you want.
Bleyseng
post Jan 5 2006, 11:28 PM
Post #93
Aircooled Baby!
Yep. they had domed 93mm pistons! Jake has a set I think
Trekkor
post Jan 5 2006, 11:37 PM
Post #94
I do things...
Either you don't know or don't want to tell...
Not to be confused with "don't ask, don't tell" in any way (IMG:http://www.914world.com/bbs2/html/emoticons/ph34r.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/chairfall.gif)
KT
McMark
post Jan 6 2006, 12:07 AM
Post #95
914 Freak!
I bumped a thread on STF and Jake promised to use his new tool (cam profiler) to reveal all there is to know about stock cams. (IMG:http://www.914world.com/bbs2/html/emoticons/smiley_notworthy.gif)
DanT
post Jan 6 2006, 12:54 PM
Post #96
And the answer is?
Drumroll please.......
r_towle
post Jan 6 2006, 01:25 PM
Post #97
Custom Member
QUOTE (Dan (Almaden Valley) @ Dec 30 2005, 01:28 AM)
So there is a lot of difference of opinion.
With a totally stock 2L engine including ignition, cam etc
do carbs work effectively?
Yes
More noticeable power?
Not really, though it sounds cool
Drivability?
As long as you warm it up its fine
MPG?
A few less MPG
Worth the hassle?
Well if your FI works, its not worth it...If you have a broken FI system and a set of carbs laying around, yes its worth it..If you have a broken FI system and would ahve to either buy parts for the FI or buy a total weber setup, its not worth it..
You can get used MPS's from Geoff for a reasonable price, and the rest of it can be had either used or new.
let the games begin! (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Lets hear it.
ok, answer to the initial questions...
r_towle
post Jan 6 2006, 01:35 PM
Post #98
Custom Member
Web cam Stock FI (it is very close to the original)
Lift 426
Duration 262
Duration @.050 224
Grind Number 73
Good overall power for engines with stock fuel-injection. Designed for mechanical lifters.
Web cam basic street Cam for carbs
423
270
234
86
Good overall power for carburated mech. street engines. RPM range 2500-5500. The perfect street cam!
I would comment that the lift is less for the carbed cam, and the duration is just a tad longer..
435
290
252
86a
Strong mid range and top end for high performance mech. street engines. Valve springs recommended.
I am noticing that the lift and duration are considerably more here..
Jake Raby
post Jan 6 2006, 01:49 PM
Post #99
Engine Surgeon
The Web cam "Stock" grind is based from a stock bus cam with solid lift.
The new cam doctor will be here in about two weeks and I'll use these stock cams to learn the new software a bit...
I'll give ya 5 pages of specs on each cam (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
BTW all those single pattern, non split duration cams catalogged are power robbers and gas burners....
r_towle
post Jan 6 2006, 02:03 PM
Post #100
Custom Member
My observation would be that is you wanted to duplicate the "carbed" cam that webcam sell, not jake, then you might be able to do it with different rockers...
You could increase the lift by playing around with those to create a stock engine that works well with carbs...possibly...
Rich
- Lo-Fi Version Time is now: 14th July 2025 - 10:32 AM
