Comprehensive list of things to do before wcc, Post your lists! |
Andyrew |
Jan 11 2006, 03:14 PM
I thought it would be a good idea for everyone to post what they intend to do before the wcc, and as then accomplish it, come back and cross out what they have finished, and when they finished it!
So.. Heres a thread! Some good guidelines. if you have a big jumble like me (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Exterior Interior Suspension Engine Things to buy So... Have at it! |
brant |
Jan 11 2006, 03:16 PM
I wanna play....
1) win lotto 2) quit job 3) get airline ticket 4) pay Aaron outrageous amount of money to drive that pretty car during the event brant |
porschecb |
Jan 11 2006, 03:19 PM
Senior Member Group: Members Posts: 1,092 Joined: 13-August 04 From: Las Vegas NV Member No.: 2,529 Region Association: None |
Try to find out if I still have a warrant out for my arrest in the state of OR. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Allan |
Jan 11 2006, 03:23 PM
Rebuild engine - In progress.
Body and paint. Re-upolster seats. New door panels. 5 lug conversion. Replace windshield wiper assembly on steering column. I will settle for the rebuild, 5 lug conversion and door panels. |
Andyrew |
Jan 11 2006, 03:32 PM
Lesse.. Mine is a little long..
Exterior Finish flares fit and finish rear f/g bumper make custom mirrors make lexan rear spoiler make custom front hood venting for radiator w/ shrouding plastic filler/ prep body primer paint Interior Install carpet Install Engman Long kit make and install custom braces. fabricate seat rails for racing seats install shifter bushing kit install dead pedal get radio to work (2 years baby...) Install fire extinguisher. Suspension Install/ fabricate front NASCAR sway bar (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Replace bearings if worn bleed brakes (yet, again) Install rear koni yellows with 275 rear springs (ebay (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) ) Powder coat wheels Align Engine Teardown and check for problems. Fix them... build and install heads fabricate oil cooler shrouding for front. Run lines and install oil cooler New exhaust system (long tube headers, magnaflow and glasspack) 3+ hours on the dyno tuning with Holley Pro Jection. Get bigger injectors if needed. Just a few things... (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
Brando |
Jan 11 2006, 03:34 PM
Hmm... did this on my blog.
Within the next month or two I will: -Increase displacement from 1.8L to 1911 with a 96mm P&C kit, bump the compression. -Install a lightened flywheel (12 or 13 lbs). -Install new chromoly pushrods. -Install a pair of refurbed stock 2.0 heads. -This should make for a sweet fast-revving 1911cc, still usable with my L-Jet (read: low investment cost, good power gains). -Re-do my door panels with some GT look... smooth with only window winder and door latch. -Weld in rear-trunk hinge console to have a closing trunk. Within the next three to four months I will: -Do some bodywork (new panels, fill some holes). -Remove the wheel-well fender lips (clean-shaven). -Change the wheel well openings from square-ish to round... who the hell makes square wheels? No need for flares (yet). -New front and rear trunk seals ($KA-CHING$) -Shave 200lbs by gutting my rubber bumpers, fabbing some custom aluminum mounts with a series of rivets, bolts, washers, and aluminum sheetmetal. -PAINT IT A PRIMARY MATCHING COLOR. Contemplating a "Stripe" clone, but 2 of them with some metallic blue? Within the next five months: -New windshield. -Wash it. |
VegasRacer |
ELVIRA Group: Benefactors Posts: 8,506 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
Purchase and Install Stereo Deck and Speakers. (IMG:http://www.914world.com/bbs2/html/emoticons/rock_band.gif)
Ferg |
Jan 11 2006, 03:49 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
For sure items:
Buy good earplugs Fix the darty feeling that shows up at about 105 (IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif) Minor trans rebuild The if I have time items: Strip undercoat, and repaint underbody white. Weld in front trunk floor move oil cooler up front Ferg. |
WRX914 |
Jan 11 2006, 03:56 PM
2.5 WRX STI hybrid powered beast Group: Members Posts: 782 Joined: 16-September 04 From: Las Vegas, NV Member No.: 2,771 Region Association: Southwest Region |
My list:
Exterior: Complete paint (car at shop, work in progress) Install third tail light (Engman) Install turn signal/brake buckets and lenses Install glass Install all window/targa/door rubber seals Install rear reflector Undercoat steel flares Install bumpers Interior: Install Momo steering wheel Install new carpet kit Install reupholstered seats w/ seat heaters Install backpad Re-finish dash panel Install sound system Install door cards Install short shifter Hook up all guages Suspension/Brakes: Install Carrera front suspension Install new trailing arms and rear shocks Install larger rear brakes Engine: Hookup Tach speedometer boost guage oil temp/pressure install intercooler and route plumbing from turbo fabricate custom exhaust Thankfully, I have Dana from Renegade to basically do all of this work while I am at my job. (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) |
bondo |
Everything but paint?
(new flared roller, has paint but needs everything else) |
WRX914 |
Jan 11 2006, 04:01 PM
John, Do you think you will be able to get that done in time? (IMG:http://www.914world.com/bbs2/html/emoticons/poke.gif) |
dinomium |
Jan 11 2006, 04:20 PM
Git on a chair son, all the good stuff is goin over yer head! Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest |
1> Make list of new old guy; cheap guy taunts
2> Shame Shane into attending at least one day 3> not paint or clean car 4> replace windshield (OR cops have some brand new laws to enforce ie 100+mph=$1000.00 fine) 5> install radio 6> give up and rent car hauler! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
rick 918-S |
Jan 11 2006, 04:25 PM
Hey nice rack! -Celette Group: Members Posts: 20,451 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Rebuild the 928 motor $$$
make new throttle linkage so I can actaully use more than 2/3 throttle (like I need it (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) ) rebuild the transaxle $$$ with the HB gear (thanks A-aron) find the electrical short that's draining my battery. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) purchase and install turbo tie rods and sway bars Front and Rear (IMG:http://www.914world.com/bbs2/html/emoticons/rolling.gif) new tires and maybe wheels If I ever sell anything around here. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) new door panels real carpet console repair send out a tach to be converted to work with an MSD and a V8 Hours and hours of details I skipped the last 2 time I painted the car. repair passanger side window (free falls into the bottom of the door at random!) complete repaint. |
Aaron Cox |
Jan 11 2006, 04:30 PM
hahahhaha!!!! i have to finish the dash face..... umm... and do oil cooler ducting and wash it.... and put the axles back in AA |
SLITS |
Jan 11 2006, 05:24 PM
Buy a running car is more like it (IMG:http://www.914world.com/bbs2/html/emoticons/poke.gif) |
Elliot_Cannon |
Jan 11 2006, 05:26 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
Change the oil.
Maybe put the roof on. Wash and wax. Cheers, Elliot |
Aaron Cox |
Jan 11 2006, 05:27 PM
gonna ever put a six in the car? just gonna sit there making motor sounds with your lips??? skline says your good at that..... (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/gayfight.gif) |
MoveQik |
Jan 11 2006, 05:43 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
Wash car.
Maybe install an aftermarket steering wheel. Evidently I have to buy a bunch of parts between now and then so Joe can take my car home after WCC and do a little work to it (IMG:http://www.914world.com/bbs2/html/emoticons/ph34r.gif) |
dlee1967 |
Jan 11 2006, 05:52 PM
V8Lurker Group: Members Posts: 540 Joined: 20-February 03 From: Splendora, TX Member No.: 327 Region Association: None |
Air Freight the 914 to the NW.......
brant |
Jan 11 2006, 05:53 PM
cool michael! congrats! how big you thinking? |
Lo-Fi Version | Time is now: 11th May 2024 - 04:21 AM |
