Question for the /6 guys, Venolia 10:5 to 1 P/C's |
Allan |
Jan 27 2006, 05:10 PM
I have a possible line on a set of Venolia P/C's running 10:5 to 1 compression to put on my 2.7.
What I'll end up with is 40mm webers, late "S" cams and 10:5 to 1 compression. What do you guys think about the combo??? |
joea9146 |
Jan 27 2006, 05:11 PM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
I think with !0.5: 1 you may have to Run Twiin Plugs.... That compression is pretty High
Aaron Cox |
Jan 27 2006, 05:12 PM
I think its gonna suck.....
. . . . . . . . when a cop busts you! LOL 200+ hp? (IMG:http://www.914world.com/bbs2/html/emoticons/chowtime.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/Jumpy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/busted_cop.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/new_shocked.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/MDB2.gif) |
rick 918-S |
Jan 27 2006, 05:23 PM
Hey nice rack! -Celette Group: Members Posts: 20,443 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) And that's a problem because? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif)
Eric_Shea |
Jan 27 2006, 05:25 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Twin Plug or Different Ignition (Crankfire??)
J P Stein |
Jan 27 2006, 05:27 PM
Webers & S cams are OK in a race motor as is 10.5:1 compression with race gas. You gots a race car?
Allan |
Jan 27 2006, 05:49 PM
Change of plans. Mechanic says compression is too high for what I need. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
Going with Mahle euro P/C's. Shooting for 9:0 to 1... |
J P Stein |
Jan 27 2006, 05:55 PM
'E' or Solex cams are a far better choice for a street car.
olav |
Jan 27 2006, 06:04 PM
Senior Member Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None |
Eddie914 |
Jan 27 2006, 06:12 PM
Unregistered |
Great combination - lots of power, and fabulous throttle response, it will even lighten the car via your wallet since you will be paying$6.00 to 8.00 per gallon for race gas (100 low lead or 110 octane leaded).
10.5:1 is a bit high for pump gas. 9.5:1 is about the limit for single plug applicaitons with pump gas (depending on the quality of the pump gas ... pump gas is not the same in all parts of the country). You might be able to reduce the compression ratio with additional cylinder base gaskets, grinding of the piston crowns or grinding of the combustion chambers. It all depends on the price of the Venolia P/Cs and the amount of custom work you are prepared to do (or are prepared to pay to have done). Eddie |
SLITS |
Jan 27 2006, 06:18 PM
Venolias were gone....actual pistons were Forged True with a CR of 11 to 12.5:1 depending upon installed height.... (IMG:http://www.914world.com/bbs2/html/emoticons/blowup.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/busted_cop.gif)
Well, back to the drawing board............. |
TimT |
Jan 27 2006, 09:20 PM
I used Venolia Pistons on the first 911 engine I ever rebuilt. It was 2.2, when my dad and I measured the bores they were ovaled and tapered.. so we had them bored.. An outboard motor guy we knew hooked us up with Venolia.. the engine, after all was said and done was 2.35L The CR was 10.1:1 when measured...
It was a screamer that engine.. Yikes almost 25 years ago LOL I drove it for a few thousand miles, then balled the car up. 10.5 Is probably the max CR unless you commit to high octane, or twin plug heads..
go for a measured 9.5 |
brp914 |
Jan 27 2006, 09:49 PM
Unregistered |
what happened to your engine? last I heard, it torqued down ok and you were on the road.
Allan |
Jan 27 2006, 09:57 PM
That's my goal... |
Allan |
Jan 27 2006, 10:00 PM
Didn't work. Head was leaking for a long time and eroded the cylinder. One thing I learned is that unless you are a very good /6 guy (or girl), you will not know how to determine a head leak by ear.... |
J P Stein |
Jan 27 2006, 10:04 PM
We (myself & another guy) rad 14.5 :1 Venolias in a 301 Chebbie back in the 60s.....drag racin'. We had to to run 2 compression washers on the plugs to keep em' off the pistons.
I ain't a big fan of trimming the deck height of 911 motors. Tain't worth the trouble for about .5 compression.....which don't give much bang for the buck. Even a point more would be worth maybe 10-15 hp & torque tops..better to get new pistons, me thinks. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
sixnotfour |
Jan 27 2006, 10:10 PM
914 Wizard Group: Members Posts: 10,422 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
His heads are gonna need a cut because of the loose cyl/ heads /errosion. |
Allan |
Jan 27 2006, 10:11 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Thanks for the advice. Mr. Make me spend more money.... |
J P Stein |
Jan 27 2006, 10:16 PM
Yeah, but that can be shimmed back up at the cylinder base. If not, you gotta cut the chain boxes to suit the heads, right? Then you can get into chain length problems which can be cured by oversized idler sprokets...I'd pass. |
Lo-Fi Version | Time is now: 6th May 2024 - 06:10 AM |
