Brake Bleeding Woes, How to bleed brakes with 240 calipers |
Huff |
Feb 14 2006, 11:12 AM
Newbie Group: Members Posts: 20 Joined: 30-March 05 From: Savannah, GA Member No.: 3,849 |
Any help out there? I am converting my 75 2.0l to Volvo girling calipers and can't get it bled properly. I have installed a new 19mm MC, all new rotors, new rear calipers, T for the proportioning valve, new Volvo 240 calipers with T's to put the two to one line conversion, SS flex brake lines and all necessary plumbing.
I have bled and bled and bled, etc... Started RR, LR, RF, LF in that order and have tried bleeding the two Volvo upper fittings in pairs and separately. The pedal is stiff after pumping brakes repeatedly with only 2"-3" of travel. When you let off and push slowly, the pedal goes 4"-6" and is mushy. Any help? |
davep |
Feb 14 2006, 11:26 AM
914 Historian Group: Benefactors Posts: 5,148 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
It almost sounds like the master has an internal leak.
Course, it could be that the ATE and the Girling are feuding. |
Lo-Fi Version | Time is now: 24th May 2024 - 02:18 PM |
