Brake Bleeding Woes, How to bleed brakes with 240 calipers |
Huff |
Feb 14 2006, 11:12 AM
Newbie Group: Members Posts: 20 Joined: 30-March 05 From: Savannah, GA Member No.: 3,849 |
Any help out there? I am converting my 75 2.0l to Volvo girling calipers and can't get it bled properly. I have installed a new 19mm MC, all new rotors, new rear calipers, T for the proportioning valve, new Volvo 240 calipers with T's to put the two to one line conversion, SS flex brake lines and all necessary plumbing.
I have bled and bled and bled, etc... Started RR, LR, RF, LF in that order and have tried bleeding the two Volvo upper fittings in pairs and separately. The pedal is stiff after pumping brakes repeatedly with only 2"-3" of travel. When you let off and push slowly, the pedal goes 4"-6" and is mushy. Any help? |
Huff |
Feb 15 2006, 08:34 AM
Thanks guys, I will try the pressure bleeding approach. My assistants are getting tired of the pedal pumping and it's costing me too many favors. Will let you know how it comes out. It should stop on a dime after the bleeding is complete. The Volvo calipers fit nicely and have almost twice as much pad area.
Huff |
Lo-Fi Version | Time is now: 24th May 2024 - 05:10 AM |
