Center console, Interferes with accelerator pedal |
Pugbug |
Feb 17 2006, 05:52 AM
Member Group: Members Posts: 449 Joined: 14-February 05 From: Victoria, BC Member No.: 3,604 |
I started building a center console so I can install a bass speaker in my car. When making the cardboard templates I found that it will run into the gas pedal. ...That can't be good.
Can anyone post a pic of the drivers side of a console, so I can see how this is dealt with? |
BarberDave |
Feb 17 2006, 07:12 AM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
On the drivers side the console side angles in away from the gas peddle,they hold it in that position with a small wood block at the fire wall end . Maybe someone has a pic. , my 914 is in storage or I'd send you one. Dave (IMG:http://www.914world.com/bbs2/html/emoticons/slap.gif) |
type47 |
Feb 17 2006, 07:36 AM
i installed a factory console and then removed it because my right foot rubbed on the console. only size 9 shoes. if/since you're building a console, you could construct that side to allow for clearance for your lead (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) foot.
rhodyguy |
Feb 17 2006, 07:54 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
here ya go.
k Attached image(s) |
MoveQik |
Feb 17 2006, 08:58 AM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
...and you can see in the pic, his foot isn't even close to rubbing the console! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Pugbug |
Feb 17 2006, 09:03 AM
Thanks for the photo.....Comfy looking sox yu got there guy.
RonD |
Feb 17 2006, 09:26 AM
Ron Diederichsen Group: Members Posts: 97 Joined: 2-July 04 From: Boulder, CO Member No.: 2,286 Region Association: None |
Had the same foot rub problem so I took the little wood block out at the back and screwed the sides together. No more rubbing.
Grimstead |
Feb 17 2006, 09:37 AM
Cheaky Monkey Group: Members Posts: 835 Joined: 20-March 05 From: Corona, Ca Member No.: 3,789 Region Association: Southern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/chairfall.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 11:52 PM |
