Cableshifter Quandry, Mcmaster cables are too short (or long) |
bondo |
Mar 3 2006, 09:46 PM
I calculated out the cables I need.. overall length of 7 and 8 feet. Everyone says mcmaster-carr has the perfect cables.. well they jump from 6 feet to 15 feet!
Where do I go to get 7 and 8 feet long cables, without having to go to some expensive custom place? If I have to go to an expensive custom place, any suggestions that are less expensive than others? |
mike_the_man |
Mar 3 2006, 11:24 PM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
My buddy used some cables for a motorboat for his Europa. Not sure where he got them from, but I'll ask. I've been thinking about trying the same.
JeffBowlsby |
Mar 3 2006, 11:31 PM
914 Wiring Harnesses Group: Members Posts: 8,505 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Royce, check Eric Ts site for his cable shiifter, maybe this will help:
http://www.etischer.com/914cableshift.html |
wbergtho |
Mar 3 2006, 11:37 PM
Senior Member Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 |
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) I Think I have you covered here. I just ordered a pair of 5/16-24 McMaster-Carr cables in lengths of 84" (part #: 1407K 93) and an 96" (part #: 1407K95). I ordered tyhem directly through McMaster-Carr and they were in stock 1 week ago. THEY DON'T APPEAR ONLINE ON THEIR WEBSITE...YOU HAVE TO CALL THEM AND ASK THEM FOR THESE PART NUMBERS). Call either (562) 692-5911 or (732) 392-6200. The super great thing is that they take orders 24/7...so you can call right now if you like. See if they can still get you a pair. I'll bet a buck you can...I DID. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Let me know if I can help, Bill Attached image(s) |
bd1308 |
Mar 4 2006, 07:29 AM
Call Terry at Terry Cables....he'll make you one.
b |
TimT |
Mar 4 2006, 09:18 AM
Aircraft Spruce will probably have something, or try a local marine supply house.
bondo |
Mar 4 2006, 11:37 AM
Sweet! If you enter the part numbers, they show up on the Mcmaster web page! I did some part number exploring and found that 1407K77 and 1407K79 are the same thing but in 1/4-28, which is the size I'm looking for. One more step in the right direction.. Thanks! |
wbergtho |
Mar 4 2006, 07:49 PM
Most of the guys here are using the 5/16 size cables. What gearbox are you going to use? (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif)
bondo |
Mar 4 2006, 08:31 PM
Sideshift 901. All the cars I looked at in the wrecking yard had cables around 1/4" including the one I took the shifter from. I figure going bigger will just add weight and a worse min. bend radius of the cable. |
wbergtho |
Mar 5 2006, 11:05 AM
Hey Bondo,
I gotcha...The 901 takes alot less effort to shift than a 915 or 930 box. My box is a 930 and I needed a bit beefier cable. You should be fine with 1/4". Did you get ahold of Mcmaster-Carr and order the appropriate cables? I thought their customer service was excellent and was amazed that they stay open all night (24/7)! The cables are very well made. I believe you'll like them when you get em. (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/rocking nana.gif) Regards, Bill |
bondo |
Mar 5 2006, 12:57 PM
Haven't ordered them yet... Just planning out what I need to buy when I get some money. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) I may end up with a 930 eventually, but it shouldn't be too hard to upgrade cables when that time comes. (one of the reasons I'm going cable shift is because I don't want to have to re-hack the body if I need to upgrade my trans) |
Phoenix-MN |
Mar 5 2006, 01:26 PM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
Bondo,
I'm currently working on a cable shifter solution for side shift box also. I've sourced a shifter and cables from a GM car that I think will work. I'm drawing up some ideas for the the linkage for the transmission end. I would like to see what you have come up with and if it is any better that what I have thought of. PM me nad we can share ideas. Thanks Paul |
wbergtho |
Mar 5 2006, 01:58 PM
Hello Paul,
I just spent over a week fabricating a cable shifter for my 930 box. I used a Mitsubishi 3000 GT shifter, McMaster-Carr 5/16" cables, and custom set up at the back. It works very well. I'll add a few pics. Bill Attached image(s) |
wbergtho |
Mar 5 2006, 02:01 PM
Oh...that's right. You are doing a sideshifter. My rear stuff is way different. But here's a pic of the shifter.
Engman |
Mar 5 2006, 04:39 PM
Zoisite Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
1/4" cables are rated to 150 lbf.
Use them at work in the mower.... Two companys make em in the US. You CAN get any custom length you want - if you order enough. Watch your angles on the attachment points - these have like a 9 degree allowable bend at the ends. Just have to place it right. M |
Lo-Fi Version | Time is now: 15th May 2024 - 05:24 AM |
