7 Pages V « < 4 5 6 7 >
> The Original Stainless Replacement Fuel Line Sets, Replace/upgrade your old plastic lines, grommets, etc.
ChrisFoley
post Nov 18 2006, 08:46 PM
Post #101
I am Tangerine Racing
QUOTE(xlchspor @ Nov 18 2006, 07:38 PM) *
So Chris for my 76 stock 2.0 ltr.I need to send you 79.00 for the set and that will cover everything? Can you tell me what else I will have to do to change my fuel lines fittings?ect?
$79 is for the two piece tunnel line set including shipping. For a more nearly stock installation I recommend the added engine compartment set. I don't recommend fittings unless you are going racing. You will also need some new high pressure fuel hose, 5/16" dia. Plan on using all new rubber hoses. New fuel filter too.
The exhaust will be in the way of installing these lines so plan on dong the installation when you have that off for another reason. It's easiest of course with the engine out too. There's a clip in the tunnel near the rear, accessed through the wiring harness pathway, that holds the stock lines down.
You might need to replace the small grommets in the firewall that the lines go through. A little silicone or ptfe spray lube will help the stainless slide easily through the rubber grommets. Preferably, any hose clamps you use are of the full sleeve type to prevent cutting into the rubber.
The job can be done alone but a second pair of hands makes it go smoother. (IMG:style_emoticons/default/beerchug.gif)
That should do it. (IMG:style_emoticons/default/smile.gif)
terrymason
post Jan 3 2007, 02:19 PM
Post #102
Do you still have any of these? I'd like to get one for my 74 with dual carbs. Not really sure of the size line I need though.
ChrisFoley
post Jan 3 2007, 04:46 PM
Post #103
I have them in stock.
Email me at c.foley at tangerineracing dot com
dagdal1967
post Jan 15 2007, 02:47 PM
Post #104
What are YOU looking at...
QUOTE(Racer Chris @ Jan 3 2007, 02:46 PM) *
Just wanted to give this a big thumbs up!!! (IMG:style_emoticons/default/thumb3d.gif)
With the help of Clay and Travis, We installed the fuel lines I ordered a month or so ago. They were a BREEZE to install and didn't have to drop the engine at all... I did have to take out the shifter to be able to guide the lines back down the center tunnel.
EXCELLENT PRODUCT Chris! Well worth the money.
Doug
biosurfer1
post Jan 15 2007, 09:53 PM
Post #105
Teener fo Life!
I also got mine and they look great! high quality items!
Tobra
post Jan 25 2007, 02:18 PM
Post #106
QUOTE(dagdal1967 @ Jan 15 2007, 12:47 PM) *
Doug
I was laying under my car the other day, wondering if it really would be possible to do without dropping the motor, did you have to remove the Exhaust?
dagdal1967
post Jan 25 2007, 06:10 PM
Post #107
QUOTE(Tobra @ Jan 25 2007, 12:18 PM) *
Nope, Didn't have to remove anything but the old plastic lines. What you will need is help and a lift to get the car far enough above you that you can see what you're doing.
When we did it, it was at Clay's place so we had the car up on the hydraulic lift in his garage. Clay as at the rear of the car pushing the new solid lines trough. I was in the cockpit guiding the lines through the center tunnel and making sure they didn't get hung up on anything. To do that I needed to take out my center console, lift the carpet and take out the two plates at the front and rear of the tunnel.
Someone else (I think it was JR) was in front to to guide the ends through the rubber grommet and then push the grommet back in place.
The whole things took about 1/2 an hour and we had to do it twice. The first time around we put the lines in the wrong sides and had trouble at the front end getting them to fit into the grommet correctly.
Big plus side was that we didn't have to take ANYTHING off, and the engine stayed firmly bolted in the car! :-)
Doug
Tobra
post Jan 28 2007, 01:59 PM
Post #108
cha'ching
Now I know what I am getting myself for groundhog day
Look at one of those swamp coolers things they use on the vintage bugs for your cooling, sort of weak, but better than nothing. I have never seen an A/C setup that I liked, worked well and did not require hacking up the car for any air cooled VW product, but they have made a lot of progress on that front.
Rick L
post Aug 31 2007, 09:08 PM
Post #109
I ordered a set one evening, got an email from Chris the next morning confirming which style, then received them 2 days later. Service doesn't get any better than that!
rfuerst911sc
post Sep 13 2007, 05:53 PM
Post #110
I received the 3/8 fuel line I recently ordered, it is a beaut in finish/quality and was well packaged. Great product great service. Thank you.
stateofidleness
post Oct 26 2007, 12:57 PM
Post #111
hey chris look for a PM lol..
i took my gas tank out yesterday and am wanting to replace whatever 30+ year old lines with your stainless lines.
as im not too familiar with all their locations and quantity, can you give me a rundown on what id need for my '76 stock FI?
do these need to be bent by us or do they come pre-bent? do you have any pictures so i can get a better idea...
and if i replace the tunnel lines and the engine compartment, what would my total be
thanks!
ChrisFoley
post Oct 26 2007, 03:37 PM
Post #112
QUOTE(stateofidleness @ Oct 26 2007, 02:57 PM) *
thanks!
No PMs. eMail me if you need additional info.
Here's my webpage with details and Paypal "buy now" buttons: Fuel Lines Webpage
Your best choice IMO is the late style 4pc set for $129. You will also need some 5/16" high pressure fuel hose and some good hose clamps.
You can find lots of installation pictures and details on this site, various topics over the past 1 1/2 years.
iamchappy
post Mar 8 2008, 10:13 AM
Post #113
It all happens so fast!
Chris i sent you an email on your recommendation for an order of SS hardlines for the turbo car.
Currently have AN 6 SS hose supply and AN 4 return.
PeeGreen 914
post Mar 8 2008, 12:47 PM
Post #114
I just received these the other day. Very nice product and easy to install. For saftey reason alone you should replace your old lines, but these look kick ass in you car to boot... Well, what you can see of them.
iamchappy
post Mar 8 2008, 04:26 PM
Post #115
Order and money sent.. Thanks
ChrisFoley
post Mar 8 2008, 04:34 PM
Post #116
QUOTE(iamchappy @ Mar 8 2008, 05:26 PM) *
Order received.
The fittings will be welded on early next week.
You may have the lines in hand by week's end.
iamchappy
post Mar 15 2008, 12:06 PM
Post #117
Got them look's great. Thanks Chris......
70Sixter
post Mar 16 2008, 01:05 PM
Post #118
Mine arrived on Friday. They really are beautiful. Good packing job, too. I'd wondered if some gorilla would kink them enroute.
iamchappy
post Mar 20 2008, 04:48 PM
Post #119
They slip right in GREAT JOB, it was easy!!!!!!
WizPorsche914
post Mar 21 2008, 08:52 AM
Post #120
My lines are 36 years old although not leaking I think I will get a set just for piece of mind. Can you just get the engine compartment ?
- Lo-Fi Version Time is now: 1st December 2025 - 09:52 AM
