Installing carbs, Simple bolt on? |
Doug Leggins |
Sep 12 2003, 06:42 PM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
I removed a stock 2.0 FI engine from a 74. The PO said that the car was parked due to FI trouble. Can I simply strip off the FI stuff, bolt on a set of carbs and (barring any other issues with the engine) expect it to run? (IMG:style_emoticons/default/huh.gif)
Or, do I need to make other changes as well? To test, I would drop my 1.7 with dual Dellorto 40's and install the 2.0. |
URY914 |
Sep 12 2003, 08:32 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,598 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Sounds easy.
But, depending on the linkage you have, it can be a bitch to get them dailed in. Paul |
Sep 12 2003, 09:36 PM
Resident German Group: Admin Posts: 41,638 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
you'll need a carb-optimized cam too.
otherwise, you won't be very happy with the results ... what's wrong with the FI ??? Andy |
Sep 12 2003, 10:26 PM
"FI problems" often aren't. I've had more than a couple of people write in to Pelican saying, "I installed carbs because I had an FI problem. But the car is still doing the same thing!" Since the FI system is relatively complex and is not understandable by the "old school" guys, it is very easy to blame for problems. Those can just as easily be caused by the ignition system, the fuel supply system, or the basic engine...
You must change to a low-pressure fuel pump if you go to carbs. You do not have to go to a new cam, but you're leaving a lot of performance "on the table" if you keep the stocker. You will have to spend time jetting them for your car, but 40s will work fine. --DD |
rhodyguy |
Sep 13 2003, 11:01 AM
the 40's will prob work better on the 2.0, depending on the jetting. check the idles, 55 is a good starting point. i suggest you get bob tomlinson's book (see picture). avail at most vw parts places or from cb performance. beware shameless plug, i highly recomend a carb linkage from TRIAD. a bit more money but a vast improvement from the others i have dealt with.
kevin |
rhodyguy |
Sep 13 2003, 11:03 AM
sorry.
Lo-Fi Version | Time is now: 16th May 2024 - 08:34 AM |
