Shorted alternator due to back cover, What remedies are needed? |
Doug Leggins |
Mar 27 2006, 04:19 PM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
Last fall when I installed my rebuilt Bosch alternator I had the same problem that several others have ran into, I shorted the alternator back cover to one of the connection posts (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) After this happened I remembered something about a post warning of trouble with replacement alternators. I searched the board and found the article warning of the problem. It was too late for me to prevent it and I really wanted to drive the car before snow flew so I left the alternator installed, removed 2 of the cover plate nuts that I could get to, wedged open the cover and slipped in a piece of heat shrink tubing for an insulator to stop the short.
The insulator "fix" has been buggin me ever since. The salt went down on the roads the day after my short drive and I have not been back out for a drive yet. But, it soon will be driving weather again so I pulled the alternator and want to fix it right. My questions are: What needs to be repaired/replaced after creating this short? Can I simply prevent the short from recurring and be good to go? Here's a link to the replacement alternator issue. Good thread, I just wish that I remembered it earlier. WARNING!-Bosch Rebuilt Alternators!! |
Aaron Cox |
Mar 27 2006, 05:01 PM
dont you just "trim" the stud?
Doug Leggins |
Mar 27 2006, 07:47 PM
I am hoping that it is that easy. Actually the washer needs a flat cut on one side to prevent the short. While the alternator is out I thought that I'd have it tested. I was just wondering if I could have damaged any other component(s). |
Lo-Fi Version | Time is now: 20th May 2024 - 12:09 AM |
