is this bolt critical? front 911 suspension, ??? |
Dr. Roger |
Apr 14 2006, 04:28 PM
i think it previously just held some debris protection shield.
but does it help keep the front suspension stationary? (IMG:style_emoticons/default/driving.gif) Attached image(s) |
Joe Bob |
Apr 14 2006, 04:38 PM
Need a pic from underneath and straight on to tell....
But ya usually need all the bolts.... (IMG:style_emoticons/default/dry.gif) Especially with THAT monster.... (IMG:style_emoticons/default/w00t.gif) |
dweymer |
Apr 14 2006, 04:50 PM
Member Group: Members Posts: 110 Joined: 22-November 05 From: orlando, fl Member No.: 5,167 |
Need a pic from underneath and straight on to tell.... But ya usually need all the bolts.... (IMG:style_emoticons/default/dry.gif) Especially with THAT monster.... (IMG:style_emoticons/default/w00t.gif) If that is the bolt that comes down through the x-member it is one of the bolts for the underbody sway bar, and the bellypan. Probably no use for you with a through the body sway. |
ClayPerrine |
Apr 14 2006, 05:50 PM
(IMG:style_emoticons/default/shocked[1].gif)
That bolt IS critical. It holds the crossmember onto the car. Fix it before you drive the car again. |
Howard |
Apr 14 2006, 05:52 PM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
I have no idea, but sure like the title of this post. Would hate to hear same in the hangar (IMG:style_emoticons/default/beer.gif)
TimT |
Apr 14 2006, 06:02 PM
What is in there now? from the pic it looks like a stud or something..
But I cant really tell from the pic you have shown us. If there is no bolt, or no stud with nut in that location. you need one bad.. before you drive the car |
ein 6er |
Apr 14 2006, 07:42 PM
Senior Member Group: Benefactors Posts: 1,115 Joined: 11-February 03 Member No.: 300 Region Association: None |
you may be right about it just holding the splash pan, it's hard to tell from the pic though.oddly, the expolded view doesn't show a bolt or stud and nut there.
doug edit ..... do you have the # 3 brace? maybe the bolt you show is where #10 and the # 4 nut attach. i think it also holds the pan on. |
BK911 |
Apr 14 2006, 09:42 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
Too funny. That is the bolt that ties the cross member into the car. On a 911 I wouldn't drive the car without it. On a 914....???? Good luck! |
dweymer |
Apr 14 2006, 11:15 PM
The bolt that holds the xmember to the tub would ummm..... go into the tub not down below into space(not a good material for locking down parts, air is funny like that). It is hidden by the mustard circle that was drawn. I will go take a pic for you.
D |
Aaron Cox |
Apr 14 2006, 11:23 PM
hat isnt the xmember to tub bolts....
those are outboard and way bigger. (you can see it to the right of the pic) i beleive its either splashpan or swaybar |
dweymer |
Apr 14 2006, 11:28 PM
hat isnt the xmember to tub bolts.... those are outboard and way bigger. (you can see it to the right of the pic) i beleive its either splashpan or swaybar Green arrow is xmember to tub, red arrow is where the belly pan/sway bar mounts, blue arrow is ride height adjustment. |
Aaron Cox |
Apr 14 2006, 11:46 PM
yup. nice vusal donnie
Dr. Roger |
Apr 15 2006, 12:02 AM
your right about the pic. it sucks... =-)
here's a better one from the other direction. there's a bolt just in the hole for no apparent reason. it came with the suspension.... unless it's for something important.... "THAT, is the question". (IMG:style_emoticons/default/mrs.K.gif) sorry, i just crack up whenever i see this smiley. LOL Attached image(s) |
John |
Apr 15 2006, 12:21 AM
your right about the pic. it sucks... =-) here's a better one from the other direction. there's a bolt just in the hole for no apparent reason. it came with the suspension.... unless it's for something important.... "THAT, is the question". (IMG:style_emoticons/default/mrs.K.gif) sorry, i just crack up whenever i see this smiley. LOL That bolt and the bracket that goes with it (a semi-straight bar) is a critical part of the aluminum front axle assembly. On the steel axles, the brace was welded to the tube, but on the aluminum ones it is bolted on. Without the brace, the aluminum axle can flex while in the car. |
Dr. Roger |
Apr 15 2006, 12:54 AM
so are saying I need to find some of those 911 braces...??
CRAP! |
Howard |
Apr 15 2006, 01:01 AM
You got your doctorate in what????
Dr. Roger |
Apr 15 2006, 01:04 AM
Hmmm,
here's the 914 suspension. yep, that brace is welded on. stock ones are pretty weak so maybe i'll fab a couple of them tomorrow... dang... =-) Attached image(s) |
Dr. Roger |
Apr 15 2006, 01:05 AM
geeeez howie... didnt you hear?? "love".
BK911 |
Apr 15 2006, 06:56 AM
pek771 |
Apr 15 2006, 08:08 AM
Member Group: Members Posts: 273 Joined: 23-November 05 From: Conover, NC Member No.: 5,175 Region Association: None |
That looks like the splash pan bolt, which also holds the sway bar backet. At least, that's what it is on my 911 SC. On a 914, it is not necessary.
Disclaimer... I will verify this later, when I feel like lying on my back on the garage floor with my camera. Pat |
Lo-Fi Version | Time is now: 16th May 2024 - 03:30 AM |
