OT: installed new Brake Controller in the Tow vehicle, Hey it tows 914s |
914forme |
Apr 23 2006, 06:26 PM
Today got done with my job, and got to work on a few items before they depart. My Truck is heading to Florida for 6 weeks with a trailer in tow. I decided it was time to upgrade my brake controller, I did some research and came up with this.Jordan Brake Controller.
Installed hope it works, will test with their trailer tomorrow. So here we go step one install the cable mount on the brake pedal, yep it uses a physical attachment to measure brake application. Big plus when pulling in the mountains. Attached image(s) |
914forme |
Apr 23 2006, 06:27 PM
Next is the cable guide, thank you GM you gave me the perfect hole palcement predrilled.
914forme |
Apr 23 2006, 06:29 PM
Next mount the controller - it has two screws, had to drill the dash (IMG:style_emoticons/default/mad.gif)
Tried to get it into one of the many pockets on the truck - could not because of cable routing. Attached image(s) |
914forme |
Apr 23 2006, 06:31 PM
Route the cables and plug in the factory wiring harness, all done.
TimT |
Apr 23 2006, 06:32 PM
Ive never seen that controller.
I have a Draw-tite controller plugged into a pigtail that Ford was nice enough to provide. Works well with my close to 10000# trailer |
URY914 |
Apr 23 2006, 08:11 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,614 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I have the trailer towing package on my Dodge and the wiring harness is prewired for after market brake controllers. Sweet!
Plug it in and go (I mean stop) |
914forme |
Apr 23 2006, 08:25 PM
Hey Paul, I figured you did not need a set of trailer brakes for your trailer. I mean what can it weigh, you have probably lightened it also. (IMG:style_emoticons/default/av-943.gif)
URY914 |
Apr 23 2006, 08:49 PM
Hey Paul, I figured you did not need a set of trailer brakes for your trailer. I mean what can it weigh, you have probably lightened it also. (IMG:style_emoticons/default/av-943.gif) My trailer is aluminum. (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/w00t.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 02:35 PM |
