5 Point Harness Installation, Show me your pics with back pad please... |
Allan |
May 24 2006, 02:05 PM
Looking to install a 5 point harness in my car and I'm looking for pictures on how it's down while keeping the stock back pad.
Jenny |
May 24 2006, 02:25 PM
Advanced Member Group: Members Posts: 4,060 Joined: 6-January 03 Member No.: 96 Region Association: None |
jhadler |
May 24 2006, 02:31 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
With or without a harness bar? I'm using a harness bar, and the shoulder belts went it super easy.
Pics are in this thread. -Josh2 |
jdogg |
May 24 2006, 02:37 PM
Member Group: Members Posts: 431 Joined: 28-January 03 From: Youngsville, NC Member No.: 204 |
Unfortunately I don' thave any pics, but what I did was locate the anchor bolts in such a way that they were in the gap between the seat and the back pad. I used quick disconnect hardware to clip the shoulder harnesses to the O-ring anchor bolt. You had to be careful to align the harnesses when sliding the seat all the way back, but it still worked pretty good! Eventually the seats and backpad will take a beating from the harness hardware. Do you need your seat all the way back to drive? If not, you can probably locate them a little closer together so they won't rub the backpad....
Allan |
May 24 2006, 02:47 PM
I don't really want to use a harness bar. I would like to keep things looking as stock as possible.
As for the seat position, I keep it 2 - 3 inches forward of the back pad. |
Allan |
May 24 2006, 02:48 PM
Doesn't it limit rear visibility? |
TROJANMAN |
May 24 2006, 02:51 PM
Looks nice in pictures......... Group: Members Posts: 5,275 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
do a search allan.
i searched the other day (because i just got a harness bar), and Trekkor had some nice pics of his 5 point belt installation. (IMG:style_emoticons/default/smile.gif) |
jhadler |
May 24 2006, 02:54 PM
I don't really want to use a harness bar. I would like to keep things looking as stock as possible. As for the seat position, I keep it 2 - 3 inches forward of the back pad. You want to keep it looking stock, but you're going to drill holes in the backpad to mount a harness??? I can pull out the harness bar in 10 minutes and the car will look (with respect to belts and backpad) as stock as when it was new. -Josh2 |
jhadler |
Doesn't it limit rear visibility? Hardly even notice it... Really. Plus, it's a really convinient location to mount a camera for autoxing... (IMG:style_emoticons/default/smile.gif) -Josh2 |
Allan |
May 24 2006, 03:01 PM
-Josh2 [/quote] Never thought about that. I also didn't know you could swap it in and out that easily. Got me thinking now... (IMG:style_emoticons/default/idea.gif) |
lapuwali |
May 24 2006, 03:11 PM
I've heard rumors to the effect that attaching the shoulder straps ONLY to a harness bar isn't legal with some racing clubs. Using the bar as a "lift" so they sit higher, and the straps are mounted to the rear firewall, is apparently allowed. If you're intended to do track days, I'd check the rules.
I'm fairly sure this is OK for AX with any club, however. |
Joe Ricard |
May 24 2006, 03:14 PM
I agree with Josh (once again)
Harness bar is required. Otherwise how do you keep the belts from compressing your spine in the event of an accident. Halness belts should tend at least an inch higher than your shoulders. Or the belt should NOT go up from it's mounting point to go over your shoulder. There should also be some sort of method to keep the two shoulder straps close together so as not to allow your shoulders to pass inbetween the two straps. |
jhadler |
May 24 2006, 03:24 PM
As with _any_ sanctioned motorsports. Check the rules. Som clubs will allow the harnesses to be mounted directly to the harness bar. Others will require that they be bolted to the firewall. In either event, if you're not using an FIA approved seat, especially if all you're using is a stock seat, you REALLY should be using a harness bar to guide the harnesses.
Joe is right about compression injuries. If the harness is pulling down on your shoulders, you run the risk of spinal compression in the event of a severe impact. The shoudler straps of the harness should pivot from a point betwen 5 degrees below to 30 degrees above the driver's (and/or passenger's) shoulders. This means that if the seat itself is not providing that pivot point (and it shouldn't anyway), that the harness should be mounted at some point either directly behind the shoulders or preferably slightly above. For us vertically challenged drivers, getting the harness pivot point above the shouders is usually not too difficult. But those of taller stature, you need to be more carefull of where those harness are A) mounted to, and (IMG:style_emoticons/default/cool.gif) where they pivot from. -Josh2 |
MoveQik |
May 24 2006, 06:01 PM
What size wheels can I fit? Group: Members Posts: 4,651 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
Allan,
There are pics in my blog of exactly what you are asking for. If you want pics with the seats forward, let me know. MW |
Aaron Cox |
May 24 2006, 06:23 PM
same here. i have eyebolts thru the firewall, and have the harnesses go up and over the harness bar....
and the block in visability is next to nada |
Aaron Cox |
May 24 2006, 06:43 PM
So.Cal.914 |
May 24 2006, 07:22 PM
Not just spinal compression, I tore both of my rotator cups in my sholders
because the harness was to low. Ouch. |
Aaron Cox |
May 24 2006, 07:27 PM
Allan |
May 24 2006, 07:31 PM
Michael you have a PM.
Aaron, when are you coming up for the party? I can use your help..... (IMG:style_emoticons/default/wub.gif) |
Aaron Cox |
May 24 2006, 07:32 PM
Lo-Fi Version | Time is now: 20th September 2024 - 07:07 PM |
