NYC area shop needed with "bench setup", 2056cc with Webcam running FI...MPS & Tuning Issues... |
ptravnic |
May 29 2006, 06:11 PM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
So I've been chasing my tail for a couple years and can't seem to get an optimally tuned engine. The FI worked perfect (as perfect as a 30yr old FI can) before the rebuild.
I've read (Paul Anders writeups) that because I changed Cams (Webcam 73 grind) the MPS will likely need tuned. I can get the car driveable but get some pinging in mid range (3200) rpm range in the higher gears but the pinging does stop if I floor it. I'm running premium gas w/octane boost but that has not eliminated the problem. What should the fuel pressure be with this setup? Anyone know of a shop with a proper bench setup that can dial in the MPS using either a DYNO or another method? Any/all leads are appreciated. -Pete |
solex |
May 29 2006, 06:21 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
Pete,
Check the search engine a couple of weeks ago some one posted a question about porsche shops in the nyc area. I know of at lest two really good shops here on long island (names and contacts are in the previous post) Dan |
ptravnic |
May 29 2006, 07:17 PM
Thx Dan.
Rich (nycchef) had that thread going. He's tried a couple and I'm just trying to find specifically a shop w/a bench setup and/or a Dyno. -pt |
porschenut |
May 29 2006, 07:26 PM
Member Group: Members Posts: 83 Joined: 15-April 04 From: Chalfont, PA Member No.: 1,929 |
Get a WB O2 sensor with data logging, you will find the issue yourself.
Regarding the fuel pressure I ran about 36 with a similar setup, also had about 300 ohms additional resistance in the head temp sensor |
TimT |
May 29 2006, 07:29 PM
We have a dyno, WB02, etc...
can we fix problems with 30 yo parts .... maybe.. |
ptravnic |
May 29 2006, 07:44 PM
Tim - You've got my attention.
I'm sending you a PM. -pt |
turboman808 |
May 29 2006, 09:24 PM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
Get one of these and have fun!!!
(IMG:http://racetunedimports.com/apex_SAFC_II.jpg) I wonder if this would work on an older porsche? I bet it would. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:36 PM |
