Gauge questions, I need em all! |
MoveQik |
Jun 4 2006, 09:26 AM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
Ok, currently the only gauges I have in my car are speedo, tach and a dummy light for oil. I can already hear you guys asking WTF is the matter with me?? Yeah, yeah, I know.
Anyways, I understand I'll be needing a different tach with the /6 conversion. In addition I want to get the other gauges to protect my new investment. What are the options? I have seen combo gauges that allow you to have everything in the factory gauge panel. And I have seen the aftermarket panels as well, such as this Gauge panel . I'm not leaning either way, I just want to go the route that will work best. Any thoughts on which gauges work best and where to get them? |
Joe Bob |
Jun 4 2006, 09:35 AM
Unregistered |
Depends on how much ya wanna spend......Palo Alto and North Hollywood Speedometer is the place to start....not cheap but you get what ya needs. VDO is prolly what you wanna get...nothing flashy but consistent...you want flash, they can redo the faces, relocated the numbers, add extra gaauges in the same body....
Tach can be converted, they can use you old gauge bodies and refurbish them. BTW....I think I have a dual sender for the oil pressure idjut light and pressure with gauge...I also have one or two other gauges that were in Frankenstealth for a short time. I removed them and went with 911 combo gauges.....which is another option. Westach will also make custom stuff....they made my CHT and Voltmeter for my 911 that replaced the clock that never worked and then magically worked when installed in Mark Bs car.... |
Eric_Shea |
Jun 4 2006, 09:40 AM
I decided to go with the 911 set - Oil Combo, Tach and Speedo. This leaves no room for the fuel gauge. This is why the 904 style combo gauges are fairly popular with conversion folk.
Someone always beat me to the available combo gauges (what I would call the proper kit) so I took that as a sign to mount the fuel gauge in the dash ala the GT cars. As Z mentioned, the speedo shops can get you there. Probably in the $500 buck range. Not a bad deal for the proper gauge in proper working condition... If you have a center consoule mount the fuel gauge there. |
lapuwali |
Jun 4 2006, 09:47 AM
You can get a 5-gauge 911-style dash from Getty. Using 911 gauges, you get fuel level, oil level (or whatever else you can get NH/PA Speedo to turn that into, like a voltmeter), oil pressure, oil temp, G light, oil pressure light, tach (914 or 911), speedo, plus one more hole for a 911 clock that you can also stuff with some Westach multi gauge units that have 1, 2, 3, or even 4 gauges. CHT, EGT, AFR, etc.
Sorry, my camera died or I'd show you a photo. SirAndy has one, and there are plenty of photos here if you can find them. |
Eric_Shea |
Jun 4 2006, 09:50 AM
(IMG:style_emoticons/default/agree.gif) didn't thunk bout that one this AM (more coffee)
MoveQik |
Jun 4 2006, 09:51 AM
gregrobbins |
Member: Team NARP Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
If you are open to a complete dash change, the switch to a 911 style dash with five gauges is very cool. Look for a kit to be offered on the classifieds soon.
I also like the arrangement where the normal fuel gauge is replace with three small 2 1/16th dedicated gauges. Check what Morphenspec is offering here on ebay. |
Joe Bob |
Jun 4 2006, 10:01 AM
Unregistered |
BTW....shitcan the oil level gauge. Waste of space as is the clock.
My next project for the 911 is to decide what to put in it's place....but first I need to figure out WHY two bench tested and working fuel senders want to stick when in the tank....I always ignore the oil level gauge and check oil via the dipstick every other gas fill up. |
Aaron Cox |
Jun 4 2006, 10:02 AM
me personally i dont like my 904 all that much.... its kinda busy....
if i did it over, i would use the 911 pressure/temp gauge, and mount the small fuel gauge in the dash |
rickyhgarcia |
Jun 4 2006, 10:08 AM
UPS truck is here... Group: Members Posts: 293 Joined: 13-June 04 From: Miami, Florida Member No.: 2,198 |
I had my gauges restored at North Holywood....great workmanship...
They make/upgrade your gauges for multiple readouts, and keep the 914 look... |
Aaron Cox |
Jun 4 2006, 10:10 AM
bad pic, but here is my setup...
(IMG:http://www.914world.com/bbs2/uploads/thumb_blog-1135138299.jpg) and full size (hotlinking from blogs isnt working right... http://www.914world.com/bbs2/index.php?auto...=attach&id=3768 |
Dr Evil |
Jun 4 2006, 10:11 AM
I like my setup with oil P, oil T, tach, speedo. I have separate fuel, CHT, and V meter.
Dr Evil |
Jun 4 2006, 10:16 AM
I got a serious thing for gauges, though. I even modified mine with a third light bung on the tach to fill in the dead spot between 3-5K, painted my needles white and added blue LEDs.
type47fan |
Jun 4 2006, 10:32 AM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
I like the 911 combo gauge in the dash and the fuel gauge in the center console. It really comes down to personal preference. I've seen the 904 installations and fuel gauges in the dash, in the radio slot, in the "A" pillar. All have their advantages. You just have to have a vision of what you want your car to be and how its parts are put together to complete that vision.
Good luck on your decision. We are here to help! Attached image(s) |
RustyWa |
Jun 4 2006, 10:44 AM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
How bouncy is that fuel gauge in the console? I had a VDO Cockpit fuel gauge in my VW Rabbit long ago and it was really bouncy.
type47fan |
Jun 4 2006, 10:47 AM
How bouncy is that fuel gauge in the console? I had a VDO Cockpit fuel gauge in my VW Rabbit long ago and it was really bouncy. I'll let you know as soon as the engine gets installed and the car is on the road again (IMG:style_emoticons/default/biggrin.gif) |
markb |
Jun 4 2006, 11:06 AM
BTW....I think I have a dual sender for the oil pressure idjut light and pressure with gauge...I also have one or two other gauges that were in Frankenstealth for a short time. I removed them and went with 911 combo gauges.....which is another option. Westach will also make custom stuff....they made my CHT and Voltmeter for my 911 that replaced the clock that never worked and then magically worked when installed in Mark Bs car.... I'd be interested in the sender. The clock still works great! (IMG:style_emoticons/default/smile.gif) Thanks mucho. |
TROJANMAN |
Jun 4 2006, 11:35 AM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
Ask Eric Shea to put you in contact with his buddy Gordo. He can get you some gauges. (IMG:style_emoticons/default/av-943.gif)
i like the 911 set up with the fuel gauge in the center console. |
MoveQik |
Jun 4 2006, 11:50 AM
I kind of like the look of the white faced gauges. Any word different manufacturers? I think I am leaning towards the aftermarket gauge plate that will allow several gauges.
Aaron Cox |
Jun 4 2006, 12:17 PM
Ask Eric Shea to put you in contact with his buddy Gordo. He can get you some gauges. (IMG:style_emoticons/default/av-943.gif) i like the 911 set up with the fuel gauge in the center console. (IMG:style_emoticons/default/mad.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 06:54 PM |
