Gauge questions, I need em all! |
Joe Bob |
Jun 4 2006, 12:19 PM
Unregistered |
bad pic, but here is my setup... (IMG:http://www.914world.com/bbs2/uploads/thumb_blog-1135138299.jpg) and full size (hotlinking from blogs isnt working right... http://www.914world.com/bbs2/index.php?auto...=attach&id=3768 Gee....mentioned that in the Playground a few weeks ago.... (IMG:style_emoticons/default/bootyshake.gif) |
Joe Bob |
Jun 4 2006, 12:20 PM
Unregistered |
I'd be interested in the sender. The clock still works great! (IMG:style_emoticons/default/smile.gif) Thanks mucho. [/quote] Call me... |
lapuwali |
Jun 4 2006, 12:36 PM
If you decide to go with the 914 style dash plate with three holes where the combo gauge goes, first, morphenspectra sells a nice fiberglass unit in the Vendors section. I believe it's cheaper and better made than the 9x unit.
Westach can also help here. They have 2" dual round gauges, and you can customize what goes where. You could have any combo of oil temp, oil press, volts, fuel, cht, egt. You can even have all six. Me, I'd probably do a dual oil temp/press gauge, a single CHT gauge, and fuel and volts in the third. |
Eric_Shea |
Jun 4 2006, 12:47 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE if i did it over, i would use the 911 pressure/temp gauge, and mount the small fuel gauge in the dash Maaaannnnnnnn.... what a copy-cat! |
MoveQik |
Jun 4 2006, 01:02 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
I hesitate to ask this and show my ignorance but here goes.....why won't the stock tachometer work?
sixnotfour |
Jun 4 2006, 01:03 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE QUOTE if i did it over, i would use the 911 pressure/temp gauge, and mount the small fuel gauge in the dash Maaaannnnnnnn.... what a copy-cat! The Factory done it since the GT's (IMG:style_emoticons/default/beer.gif) |
Eric_Shea |
Jun 4 2006, 01:15 PM
QUOTE The Factory done it since the GT's Yeah I know... inside joke cause Jr. A-W-L-W-A-Y-S copies me. Even when he doesn't, (such as this case) he wishes he had. |
jasons |
Jun 4 2006, 03:05 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
I hesitate to ask this and show my ignorance but here goes.....why won't the stock tachometer work? Tachs are sync'd with the pulses off the coil. Basically in a nutshell 4 pulses off the coil of a 4 cyl motor = one revolution. 4 pulses off the coil of a 6 cyl equal 4/6 or 2/3rds of a revolution. So... Your tach has to be calibrated to the pulses. If you put your 4 tach in your car with a 6, it will always read more RPM's than actual. Because your 6 will pulse the tach 6 times per revolution, your tach will see the first 4( of 6) pulses as one revolution, when its actually only 4/6 or 2/3rds of a 6cylinder revolution. I don't know if you can follow that, but I hope it helps... |
Joe Bob |
Jun 4 2006, 03:21 PM
Unregistered |
I gota $19.95 Pep Boys Special that has a 4-6-8 switch on the back....strap it to the steering column....woohoo, Ricardo Racer braduh.....worked great on Frankenstealth...
gregrobbins |
Jun 4 2006, 09:12 PM
Member: Team NARP Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
Nice 911 five gauge kit for sale in the classifieds. Good price too.
Lo-Fi Version | Time is now: 8th June 2024 - 10:07 AM |
