Canton oil filters, Remote filters |
spunone |
Jun 14 2006, 04:12 PM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
Anyone use the Canton remote oil filters? if so what size and where did ya mount it .And are you happy with it . (IMG:style_emoticons/default/screwy.gif)
spunone |
Jun 14 2006, 04:55 PM
(IMG:style_emoticons/default/icon_bump.gif) Come on somebody out there must have one??? (IMG:style_emoticons/default/rocking nana.gif)
TimT |
Jun 14 2006, 05:16 PM
Have a canton filter on my 911 its mounted up frontright before the thermostat and cooler. Dont have any pics yet
brant |
Jun 14 2006, 06:00 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I've got one up in the front trunk on my old black car.
(front cooler, this filter, and used to be an accusump up there too) brant |
Heeltoe914 |
Senior Member Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 |
I have one and it works great had it on a race car with a 3.2 for 7 years. 80K Miron I think. I have rebuilt the motor three times and the oil was always very clean. Its good extra insurance. I mounted mine in the front truck just before the cooler.very low in the truck.AN 12 fittings. I ordered it direct for factory.
spunone |
Jun 14 2006, 06:10 PM
So far seems like you all mount them up front what size are you guys using?? I guess there's no problem mounting them so far from the motor? (IMG:style_emoticons/default/thumb3d.gif)
Aaron Cox |
Jun 14 2006, 06:51 PM
So far seems like you all mount them up front what size are you guys using?? I guess there's no problem mounting them so far from the motor? (IMG:style_emoticons/default/thumb3d.gif) mount it before your thermostat tho... i would hate to see your oil only filtered when hot... |
TimT |
Jun 14 2006, 07:28 PM
Not sure what kind of oil system your building, or whether its for a /4 or a /6
I have very little experience with the /4s. But, with a /6 we run -12 or -16 to the front of the car, and the oil return is either -16, or -20. Although on my 914/6 the return is -12, also my 914 doesnt have a front mounted tank. The oil should go through the filter first > then thermostat > cooler> dry sump tank > return to engine.. |
spunone |
Jun 14 2006, 07:44 PM
Great thanks for everybodys input.and it's just a 4 kind of checking my options Thanks all
TimT |
Jun 18 2006, 04:35 PM
Found a pic of the oil system in my 911, you dont see the oil cooler
Lo-Fi Version | Time is now: 18th May 2024 - 04:50 PM |
