another question on tires |
plumbfor6 |
Jun 14 2006, 06:09 PM
trying to restore Group: Members Posts: 5 Joined: 5-March 06 From: Hemet, Ca Member No.: 5,670 |
i have a 75 with the 1.8 engine and need new tires, the rims on it when i purchsed it is 15 in. empi 8- spoke. my main concern is side clearance between tire and body i want to get away from 165sr15 if possible.
Jun 14 2006, 06:19 PM
Go out and check your current tires, which I assume are 165s? How much clearance do you have between the tire and the fender? Inner fender and outer fender? On both rear wheels? Yes, that's four measurements you need to make. If you've got about an inch (or more!) in all four places, you're good to go to 205s. If you've got 3/4 of an inch (or more) in all four places, 195s should fit nicely.
If any single one of the measurements is less than 1/2", you should consider getting different wheels so you can fit decent tires under your stock fenders. --DD |
plumbfor6 |
Jun 14 2006, 07:41 PM
i have 1/2" on outside 2"on inside roughly, there is 1 1/2" from the top of the tire to the the top lip of the fender opening. would a 60 or 65 series make a differance?
porschecb |
Jun 14 2006, 07:51 PM
Senior Member Group: Members Posts: 1,092 Joined: 13-August 04 From: Las Vegas NV Member No.: 2,529 Region Association: None |
I run 205/55/15 on my Empi eight spoke. But check the width of the tire you might want to use! They all vary! I rolled my wells just a bit. Real close they are. (IMG:style_emoticons/default/idea.gif)
plumbfor6 |
Jun 14 2006, 08:00 PM
was it hard to roll out the fender? im a little new on trying or doing modifications.
porschecb |
Jun 14 2006, 08:16 PM
I just bent the inside lip up just a bit. Thats what happend when i tried to roll it. A baseball bat works (old school) Just be careful you do not want pull the fender out to far doing this (ask me how I know). (IMG:style_emoticons/default/dry.gif)
plumbfor6 |
Jun 14 2006, 08:21 PM
ok (IMG:style_emoticons/default/blink.gif) how do you know?
lapuwali |
Jun 14 2006, 08:44 PM
This is well covered in the General FAQ
Jun 14 2006, 08:59 PM
i have 1/2" on outside 2"on inside roughly, there is 1 1/2" from the top of the tire to the the top lip of the fender opening. would a 60 or 65 series make a differance? Is this for the rear fenders? Both fenders? Remember, 914s often have slightly different clearance on the left side than on the right side. If you have 1/2" clearance on the outside, it sounds like you have wheels with an offset that is not well suited to the 914. I wouldn't want to try anything wider than about a 175-width tire, if you only have 1/2" clearance from your current 165s. You can pull the fenders outward or roll the fender lip flat, which can help a little, but after a certain point things start looking odd. The lower corners of the fender start to pull inwards, and it looks pretty funny. I personally would start thinking very hard about finding wheels that have a better offset for the 914. The stock wheels work pretty well... --DD |
Aaron Cox |
Jun 14 2006, 09:24 PM
basically... you have Beetle offset wheels...
Joe Ricard |
Jun 15 2006, 04:58 AM
Buy some FUCHS, MAHLE or (late) Pedrini wheels. they all have the backspace you need.
Benefit in Fuchs are usually pretty straight and lighter and oh so sexy. |
Lo-Fi Version | Time is now: 28th May 2024 - 12:01 AM |
