QUOTE(plumbfor6 @ Jun 14 2006, 06:41 PM)
i have 1/2" on outside 2"on inside roughly, there is 1 1/2" from the top of the tire to the the top lip of the fender opening. would a 60 or 65 series make a differance?
Is this for the rear fenders? Both fenders? Remember, 914s often have slightly different clearance on the left side than on the right side.
If you have 1/2" clearance on the outside, it sounds like you have wheels with an offset that is not well suited to the 914. I wouldn't want to try anything wider than about a 175-width tire, if you only have 1/2" clearance from your current 165s.
You can pull the fenders outward or roll the fender lip flat, which can help a little, but after a certain point things start looking odd. The lower corners of the fender start to pull inwards, and it looks pretty funny.
I personally would start thinking very hard about finding wheels that have a better offset for the 914. The stock wheels work pretty well...
--DD
