Quick release steering wheel hub, What are you guys using |
hars914 |
Jun 30 2006, 05:47 AM
Member Group: Members Posts: 114 Joined: 6-January 03 Member No.: 94 |
I am in the process of getting a quick release hub for my new track car.
What are you guys using? I have a Momo wheel. I need one that does not push the wheel a lot closer to the driver. Is a weld on good? |
Jeroen |
Jun 30 2006, 06:08 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
If you don't want one that doesn't move the wheel (much) closer, you should check with OG Racing
TimT |
Jun 30 2006, 07:11 AM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
I have a Teknic, moved the wheel out about 3/4 in which gets your knuckles away from the turn signal/wiper stalks.
I think it was $99 |
smdubovsky |
Jun 30 2006, 11:53 AM
Member Group: Members Posts: 331 Joined: 27-September 04 From: Silver Spring, MD Member No.: 2,837 Region Association: MidAtlantic Region |
Search pelican. I've recently tried the ball bearing types and like them MUCH better than the splined type. Definately stay away from the splined sparco one the OG racing sells. The tekniq might be the thinnest though. Going to a flat dish wheel like the momo prototipo can cancel most of the depth change of any Q.R. though.
SMD |
Jeroen |
Jun 30 2006, 02:38 PM
you can also check http://www.goingsuperfast.com
(yeah, I know, cheesy name (IMG:style_emoticons/default/rolleyes.gif)) |
nebreitling |
Jun 30 2006, 02:58 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
jesus christ, did a 9-year old make that site?
Attached image(s) |
Jeroen |
Jun 30 2006, 06:43 PM
yep, the site looks like total crap
but he does answer his e-mails and his prices are decent, so who cares? |
nebreitling |
Jun 30 2006, 08:23 PM
i agree -- i just got a kick out of that pic... i'm actually considering buying that exact QR!
Jeroen |
Jul 1 2006, 05:06 AM
just so you know
that ballbearing hub will only fit on a momo/sparco/omp style wheel and hub NOT on a nardi/personal/raid hub |
smdubovsky |
Jul 1 2006, 03:05 PM
The "D1-spec" QR he has on his site for $100 can be found on ebay for ~$22 shipped! I have one;) I have both the D1 and a Netami. Both are drilled for both the momo and nardi bolt patterns on each end.
FWIW, I cut the "hub" off an old stock steering wheel to get the splined part & turn cancel ring by simply drilling out the rivets. I then drilled it to the momo patter and mounted the QR/wheel directly to it to avoid having the additional thickness of a momo adapter. SMD |
J P Stein |
Jul 1 2006, 09:15 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
I actually need to move the steering wheel (Momo) about 1.5 inches closer to me.
I have short legs & long arms, but have to muscle the wheel a bit. (IMG:style_emoticons/default/biggrin.gif) Any recommendations? |
Jeroen |
Jul 2 2006, 07:28 PM
JP, you can get a spacer (goes between the hub and the wheel) or a deep dish wheel
a QR will move it closer to you too AND it's easier to get in/out of the car (specially if the wheel is close to you) |
J P Stein |
Jul 2 2006, 07:31 PM
Lo-Fi Version | Time is now: 16th May 2024 - 09:45 AM |
