Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
Well, Headrage and I have muddled thru the Crane install....the instructions SUCKED!!!!
NOW, the MSD Instructions suck worse....anyone BTDT? |
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
Yes BTDT, about 10-12 years ago... I dont remember the details, but I do remember it was pretty straightforward
Joe Bob |
OOpsie....
Attached thumbnail(s) ![]() |
Joe Bob |
We used the white wire and connected to the used to be negative lead from the coil from the Crane Optical unit....
We are also getting less than 12volt at the red wire which is switched power.... |
Flat VW |
Illegal Soapbox Derby Racecar ![]() ![]() ![]() Group: Members Posts: 1,692 Joined: 13-November 04 From: Phoenix, AZ Member No.: 3,105 ![]() |
john rogers |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 ![]() |
On the MSD box the small red wire has to have switched 12 volts. The white wire should feed to the yellow wire on the crane box if it is the old XR700 system and the red wire on the crane box should also get 12 volts of switched power. The multi pin plug on the crane box goes to the distributor and the other two wires on the MSD box go to the coil + and -. There will be three wires connected together at the power source.
Joe Bob |
is there a way to self test the MSD box?
Matt Romanowski |
Senior Member ![]() ![]() ![]() Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 ![]() |
Yes, It's in the instructions.
CHECKING FOR SPARK If triggering the ignition with the White wire: 1. Make sure the ignition switch is in the “Off” position. 2. Remove the coil wire from the distributor cap and set the terminal approximately 1/2" from ground. 3. Disconnect the MSD White wire from the distributor’s points or ignition amplifier. 4. Turn the ignition to the On position. Do not crank the engine. 5. Tap the White wire to ground several times. Each time you pull the wire from ground, a spark should jump from the coil wire to ground. If spark is present, the ignition is working You can find them at http://www.msdignition.com/pdf/frm23775_6520.pdf |
Joe Bob |
Ok...pulled the MSD and hooked it back to the Bosch CDI....we are only getting 6v switched power to the + side of the coil.....it runs...but that seems low.
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
Okay, just got home.
Thanks Mike for the help today. At least we got the Crane working. Talked to Slits on the way home and he says the optical trigger may need some adjustment to get the timing right. I'm going to see if I can work on it tomorrow with a fresh head. Mike, I don't remember if we were feeding 12 volts to the Crane directly with the MSD installed? BTW, I hate electrical crap!!! |
Joe Bob |
Check yer email....John called back....
Allan |
Check yer email....John called back.... Which e mail? Home or office? Home is agmoore4@sbcglobal.net (IMG:style_emoticons/default/wink.gif) |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
if both the crane and msd need a switched 12v source, you need to split off the original coil + wire...
turboman808 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States ![]() |
Just took an MSD ignition off my car yesterday. Good ridance.
Aaron Cox |
send it my way.
AA |
Allan |
Aaron Cox |
sorry turbo....
but they do make a big difference on these cars...... multiple spark dishcarge below 3k and an amplified spark above that.... use it with a monster CDI coil, and you will feel the difference and NEVER foul a plug |
turboman808 |
Took it off my civic. Didn't do anything except burn out coils and eat up the distributor caps really fast.
914 has coil packs. Wish I could get those for the honda as well. |
Allan |
I was re-reading the Crane instructions and on the first page is says that the XR700 needs a ballast resistor. On page ten it says that only the XR300 needs it. (IMG:style_emoticons/default/confused24.gif)
I think I may just take Aarons advice and go with a Pertronix... |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
I was re-reading the Crane instructions and on the first page is says that the XR700 needs a ballast resistor. On page ten it says that only the XR300 needs it. (IMG:style_emoticons/default/confused24.gif) I think I may just take Aarons advice and go with a Pertronix... Friends don't let friends use Pertronix .......................... The Cap'n |
Lo-Fi Version | Time is now: 13th July 2025 - 10:40 AM |
