Question about rear springs |
Porsche Rescue |
Oct 25 2003, 09:38 PM
I am replacing rear shocks on a 914-6 with stock Boges. I want as close to new stock ride as possible.
There are a set of new springs available, aftermarket 80 lb. Does anyone know if they would be about the same stiffness as new stock? I hear about 100, 140, 180 lb. etc, but have no idea what factory rate was. |
ChrisReale |
Oct 26 2003, 01:47 AM
Factory rate was anything from 60#-100# 's. If you get the 100# springs, you will sit high in the rear unless you have adjustable spring perches
davep |
Oct 26 2003, 08:46 AM
914 Historian Group: Benefactors Posts: 5,138 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
The standard spring rate was about 60 lb/in. There were a few variations. Mid 72 they went with longer springs that increased the preload. The /6 springs were thicker wire than the /4. Most of my factory data lists the load as installed; i.e. the load the spring will carry without deflecting. I wish they had listed the spring rate instead. The dots on the springs, 1 to 3, were rate groupings; i.e. use a pair with the same number of dots. Aftermarket springs are not broken down in the same way. Are they matched better? Who knows. They also had optional springs available with 70, 80 and 90 rates for setting up the race cars.
DaveP |
TimT |
Oct 26 2003, 08:48 AM
I use #350 springs on my car (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/lol3.gif)
cant help with stock cars though.. |
Lo-Fi Version | Time is now: 7th May 2024 - 08:21 PM |
