Will 951/944 turbo calipers fit under 15" fuchs?, Lets make an adapter to make them fit :) |
Aaron Cox |
Oct 3 2006, 04:54 PM
2 questions -
1) will they fit under 15" fuchs? 2 ) i know they are 3.75" spacing....and you can slot the ears to fit on a 3.5" strut... would an adapter be feasible to mount them to a 3" spacing strut? |
ClayPerrine |
Oct 3 2006, 08:43 PM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I have 944 turbo calipers all the way around.
The fronts have to be redrilled to fit the 3.5" bolt spacing. The rears had to have a custom mount fabricated. No, the 15" wheels will not fit over the calipers. The 16" wheels are a tight fit. |
Aaron Cox |
Oct 3 2006, 08:47 PM
I have 944 turbo calipers all the way around. The fronts have to be redrilled to fit the 3.5" bolt spacing. The rears had to have a custom mount fabricated. No, the 15" wheels will not fit over the calipers. The 16" wheels are a tight fit. what are you doing for a P brake? (911 ebrake right?) what about the adapter idea to mount them more inward on the rotor... boxster calipers fit under 15"... these are smaller..... seems like an easy equation (IMG:style_emoticons/default/smile.gif) an adapter that goes from 3" spacing to 3.75" and puts the caliper more inward on the rotor... big VOLVO 4 pistons fit.... again.. bigger than these 951 calipers |
Lo-Fi Version | Time is now: 21st May 2024 - 01:00 PM |
