Will 951/944 turbo calipers fit under 15" fuchs?, Lets make an adapter to make them fit :) |
Aaron Cox |
Oct 3 2006, 04:54 PM
2 questions -
1) will they fit under 15" fuchs? 2 ) i know they are 3.75" spacing....and you can slot the ears to fit on a 3.5" strut... would an adapter be feasible to mount them to a 3" spacing strut? |
Matt Romanowski |
Oct 4 2006, 10:06 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
I don't think I'm getting this. With the adapter peice, is it going to be a flat piece of steel? If so, then you're offset some amount. Is that what you're trying for to center on the rotor?
If it's not flat, I would be worried about the thickness of it where it jogs inbetween the holes. I thought about a couple ideas like this when I did mine and just decided it was easier to cut the old brackets off and put on new ones. |
Lo-Fi Version | Time is now: 21st May 2024 - 11:13 AM |
