Will 951/944 turbo calipers fit under 15" fuchs?, Lets make an adapter to make them fit :) |
Aaron Cox |
Oct 3 2006, 04:54 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
2 questions -
1) will they fit under 15" fuchs? 2 ) i know they are 3.75" spacing....and you can slot the ears to fit on a 3.5" strut... would an adapter be feasible to mount them to a 3" spacing strut? |
ClayPerrine |
Oct 4 2006, 12:34 PM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Just an update... The welding on the rear trailing arm ends up with the tab farther inboard. So when you weld it on, it attaches behind the factory weld where the bearing carrier attaches to the trailing arm. You end up not welding the cast iron, but the steel behind the bearing carrier.
And I looked at the adapter thing, the mounting tab will not allow enough clearance to clear the bottom edges of the pads with an adapter plate, front or rear. Even the monoblocks with the adapter blocks have to have the inboard pad milled off slightly to clear the factory 914 caliper mount. |
Lo-Fi Version | Time is now: 21st May 2024 - 03:13 PM |
