Will 951/944 turbo calipers fit under 15" fuchs?, Lets make an adapter to make them fit :) |
Aaron Cox |
Oct 3 2006, 04:54 PM
2 questions -
1) will they fit under 15" fuchs? 2 ) i know they are 3.75" spacing....and you can slot the ears to fit on a 3.5" strut... would an adapter be feasible to mount them to a 3" spacing strut? |
Matt Romanowski |
Oct 4 2006, 02:32 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
I think Clay is right about the welding. I can take a look at my car tonight when I swap wheels around.
Either way, if it is cast *iron* it is harder to do than just being cast steel. I can't imagine they used regular cast iron. With the way people describe hammering on wheel bearings..... |
Mueller |
Oct 4 2006, 02:55 PM
I think Clay is right about the welding. I can take a look at my car tonight when I swap wheels around. Either way, if it is cast *iron* it is harder to do than just being cast steel. I can't imagine they used regular cast iron. With the way people describe hammering on wheel bearings..... I really think it's cast steel, not your typical cast gray iron like the brake rotors... |
Lo-Fi Version | Time is now: 21st May 2024 - 03:21 PM |
