Making a Sport muffler for a /4 Header, using a 911SC Muffler. Project "tri-tip" |
jd74914 |
Jan 8 2007, 10:19 PM
Its alive Group: Members Posts: 4,781 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Instead of drilling thru the pipe walls use a dull bit and bump in indents the size of set screw tips, then weld the nuts on the outside of the caps like you plan on. That way there is a little something for the set screws to "bite into" without putting then through the pipes.
I hope that made sense. |
Crazyhippy |
Jan 8 2007, 11:04 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
tool box latches?? a hook on the pipe, and the latch mechanism on the cap??
Velcro? Duct Tape? BJH |
Aaron Cox |
Jan 8 2007, 11:30 PM
Instead of drilling thru the pipe walls use a dull bit and bump in indents the size of set screw tips, then weld the nuts on the outside of the caps like you plan on. That way there is a little something for the set screws to "bite into" without putting then through the pipes. I hope that made sense. thought about that too... the material isnt all that thick....... what about something that expands from the inside??? stick it IN the tube and tighten.... |
Twystd1 |
Jan 9 2007, 12:05 AM
AA...
Did ya ever wonder how those cheap computer desks at IKEA have telescoping legs????? That is your answer. Totally hidden. Unsrews. Get's tighter with heat. And we can make em..... With a little help from SpunOne... (Paul) Think about it.... Thats your brain teaser for tonight. C |
Aaron Cox |
Jan 9 2007, 12:10 AM
AA... Did ya ever wonder how those cheap computer desks at IKEA have telescoping legs????? That is your answer. Totally hidden. Unsrews. Get's tighter with heat. And we can make em..... With a little help from SpunOne... (Paul) Think about it.... Thats your brain teaser for tonight. C head hurts.... 5 subject brain gang bang already today... care to make it less painful? |
jd74914 |
Jan 9 2007, 08:46 PM
Instead of drilling thru the pipe walls use a dull bit and bump in indents the size of set screw tips, then weld the nuts on the outside of the caps like you plan on. That way there is a little something for the set screws to "bite into" without putting then through the pipes. I hope that made sense. thought about that too... the material isnt all that thick....... what about something that expands from the inside??? stick it IN the tube and tighten.... you could do that too, i've seen something like that, where did i see it? hmm |
Aaron Cox |
Jan 13 2007, 06:20 PM
ok... so i went night boarding last night.... at mt high... froze my nuts off...
woke up early this AM.... pulled the muffler... finished the mount... centered it... all is well... hooked up the DLEE tow setup... and drove down to meet up with clayton (twystd1) and jimmy... we then rocked out to jimmy's favorite exhaust fab place.... 30 bucks later... and its all hooked up with a nice flange and copper collector gasket.. the guy did some bitchin welding... so we played around with what 1 pipe vs 2 pipes vs 3 pipes sounds like.... DUDE... all i can say is WOW. it rocks. nice and throaty at idle... and down low... really throaty thru the RPM range... and sounds great. then when cruising (think freeway speeds) it is Q U I E T! i can have a conversation in the car again LOL!!! i plan on pulling it off and painting it with POR 20 soon. thanks to clayton, jimmy, and most of all craig downs. ill upload some pics and maybe a video later. AA |
So.Cal.914 |
Jan 13 2007, 06:44 PM
Aaron I don't know if you figured out a way to plug those sport pipes but I
have an idea for you. Go to your FLAPS and ask to see quick replace freeze plugs. They come in many sizes, you just put them in the hole and tighten the nut in the center of it. A rubber is squashed and presses outward and seals the hole. It withstands HOT water under preasure. You could replace the rubber with hi-temp silicone rubber (not silicone in the tube), I used the silicone rubber for exhaust connections on my nitro benzene out rigger hydro's (Hot) , lasted very well and no holes. |
Aaron Cox |
Jan 13 2007, 06:46 PM
clayton and i devised a sinsister way to make sick caps... that remove with ease....
whenever we get around to making em that is LOL paul - good suggestion! will make a great plan B |
Twystd1 |
Jan 13 2007, 07:22 PM
Yup,
AArons wacky exhaust sounds very nice... But that ain't THE GOOD PART......... The twin exhaust simply looks elegant and kinda tough at the same time. I have see this setup before. And never ceases to amaze me how good they look. I don't know how they perform from a dyno perspective. That is unknown. But I wil tell you one thing... it improved a tuning stumble AA always had down low... In part transition.... (I mean his car... Not him) Cause that problem is gone now.... Who woulda thunk the muffler woulda fixed this constant source of pissing me off. Thats a win win in anybodys book.... CRAP.... Now I have to go make one for me...... Cudos to Craig Downs and AA for a job well done. And Jimmy... Thanks for the hookup. C |
Eric_Shea |
Jan 14 2007, 12:36 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
You mean he finally finished it?? (IMG:style_emoticons/default/ohmy.gif)
Aaron Cox |
Jan 14 2007, 02:23 PM
just took it for a drive... and did some video... but my mic on the camera sucks balls....
pics before its painted.... Attached image(s) |
Aaron Cox |
Jan 14 2007, 03:09 PM
my digi cam sucks at video......
http://www.youtube.com/watch?v=Q_GxinepsHk http://www.youtube.com/watch?v=rKRZUW59vNk http://www.youtube.com/watch?v=h7Luqqa_sn8 |
So.Cal.914 |
Jan 14 2007, 03:28 PM
Very well done Aaron, can you get a pic of how you hung it on the car?
thesey914 |
Jan 14 2007, 04:04 PM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
Thats looks really really good. Looks like you have a six in there (IMG:style_emoticons/default/smile.gif)
seanery |
Jan 15 2007, 09:29 AM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I smell a CLASSIC!
congrats to you Aaron! |
Aaron Cox |
Jan 15 2007, 03:36 PM
Very well done Aaron, can you get a pic of how you hung it on the car? sure! when it comes off in the upcoming weeks to get painted w/ POR 20.. ill take a pic of the mount... really simple (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 5th June 2024 - 07:12 AM |
