What exactly does corner balancing mean? |
ChrisReale |
Mar 6 2003, 07:55 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Feed my head with knowledge (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif)
vortrex |
Mar 6 2003, 08:05 PM
Senior Member Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None |
Zeke |
Mar 6 2003, 08:10 PM
Never left, but not right.... Group: Members Posts: 381 Joined: 26-January 03 From: Long Beach CA Member No.: 197 Region Association: None |
It's where you stand on one corner of the car on one foot and see if you can maintain your balance, i.e., corner balancing. You should not try this when the car is moving.
On the other side of the coin, you could weigh each corner and note the descrepencies. If you find one corner heavier than the one opposite at the same end, and the opposite corner diagonally also heavier that it's opposite at it's end, your car's weight is jacked. Follow that? It gets worse. Excactly what you want if your car is a NASCAR stock car. |
TimT |
Mar 6 2003, 08:39 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
when you corner balance, you should have ballast equal to your weight in the drivers seat. then fiddle with the spring perches, torsion bars etc, until you have have the left/right numbers as close a possible. I dont know the bias front/rear for a 914 but you should try to make front and rear bias match also..
basically you want each wheel to carry the load it is supposed to (ideally) on my 911 i was able to get these readings with a fat ass ballast ( like me) in the drivers seat RL410 RF403 RL638 RR 636 all these meassurements are taken with sway bars disconnected... no preload in the suspension. |
mskala |
Mar 6 2003, 09:50 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Tim,
I'll assume you were just trying to say it with the fewest words, but the way it reads it is not right. Weight cannot be moved front to back, or side to side. But it can be put on the diagonals in the best way. You want the percentages of the left side weight F/R to be the same as the percentages of the right side weight F/R. That doesn't mean the diagonals are the same weight, or that the fronts are the same weight or the rears are the same weight. Mark S. '70 914-6 |
Dave_Darling |
Mar 6 2003, 10:27 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
There is one school of thought that holds that you want to make the cross-weights even. (LF+RR versus RF+LR) I figure that the differences between that method and the other are probably in the level of "noise". At least, when compared to my driving "skills".
--DD |
Lo-Fi Version | Time is now: 28th April 2024 - 12:44 AM |
