What causes bearings to look like this? |
mike373 |
Dec 10 2006, 07:48 PM
Member Group: Members Posts: 198 Joined: 3-August 05 From: san diego, ca Member No.: 4,536 |
Finally got my case split on the engine I will be rebuilding..... The cam bearings look pretty torn up!!! Flaky pieces were coming right of them. What causes this condition?? And what causes the marks on the main bearings also?
Thanks, Mike Attached image(s) |
mike373 |
Dec 10 2006, 07:50 PM
Finally got my case split on the engine I will be rebuilding..... The cam bearings look pretty torn up!!! Flaky pieces were coming right of them. What causes this condition?? And what causes the marks on the main bearings also? Thanks, Mike More pics............. Attached image(s) |
Twystd1 |
Dec 10 2006, 07:53 PM
Can you wipe off the bearings and take close up shots?
That will give us a MUCH better idea of what the problem is. Also, can you shoot some pics of the rod bearings and the crank and cam journals? AND.... What made you tear the engine down in the first place?????? The more data you give us. The better data you recieve. Cheers, !!!!!!!!!!! Twystd1 |
Twystd1 |
Dec 10 2006, 07:54 PM
That was fast....
What else ya got..????? C |
smontanaro |
Dec 10 2006, 08:00 PM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
When taking close-ups make sure your camera is in the correct mode. Many will have a flower icon for closeups (and mountains for far away shots). Your pictures look to me like you're either too far away to get a good close-up or you're too close for the "auto" setting.
Skip |
mike373 |
Dec 10 2006, 08:02 PM
That was fast.... What else ya got..????? C The quality sucks because my camera sucks... 2 megapixel. (IMG:style_emoticons/default/sad.gif) This engine has been sitting in my garage, waiting to be turned into a 2056. Finally got the fundage, so I opened 'er up. Main journals dont look too bad, a little streaking. Dont have the rods off the crank yet. Mike |
Twystd1 |
Dec 10 2006, 08:11 PM
Just humor me on this....
also take a pic of the inside of the oil pump cover.... How clogged were the fins of the oil cooler? If any? What did the oil look like when ya drained it? What kinda crap did you find in the block after dissesembly? (bearing metal, etd?) Do you have naked pictures of Howard? Forget the Howard thing..... Just send up the pics..... Cheers, C |
mike373 |
Dec 10 2006, 08:17 PM
Just humor me on this.... also take a pic of the inside of the oil pump cover.... How clogged were the fins of the oil cooler? If any? What did the oil look like when ya drained it? What kinda crap did you find in the block after dissesembly? (bearing metal, etd?) Do you have naked pictures of Howard? Forget the Howard thing..... Just send up the pics..... Cheers, C Hahahahahahha!!!!! Too funny... I will take more pics tomorrow. Done for the day. Mike |
sww914 |
Dec 10 2006, 08:24 PM
Test the camera on your wife or girlfriend first. It won't help the bearing pics much, but it will make us all feel more generous.
john rogers |
Dec 10 2006, 08:28 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I've had bearing flake twice, once on a stock 2L with close to 150,000 miles on it and that was being beat up from old age. The other was in my 2.8L race engine after revving it to 7500 RPM repeatidly on a race weekend, the bearings were beat up. Happens to VW drag racing engines that rev to 10 or 11K RPM after about 10 runs too.
Jake Raby |
Dec 10 2006, 08:44 PM
Eroded cam bearings are not an oddity, especially with older sets and original, never before rebuilt engines...
What makes it worse are certain oils and people not changing them often enough.. Pennzoil and Quaker sludge are bad about this.. Its not uncommon at all.. |
URY914 |
Dec 10 2006, 09:31 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,578 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Well lets see, the only thing that should touch those bearings is oil, so I say its oil related.
Jake Raby |
Dec 10 2006, 09:44 PM
You can also blame the stock oil pump and the factory oil filter housing.. When we go to full flow these issues are history..
jwalters |
Dec 10 2006, 09:51 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
Eroded cam bearings are not an oddity, especially with older sets and original, never before rebuilt engines... What makes it worse are certain oils and people not changing them often enough.. Pennzoil and Quaker sludge are bad about this.. Its not uncommon at all.. yes I agree, sludge is very, very badd!! |
Joe Ricard |
Dec 11 2006, 09:45 AM
Sludge comercials are stupid. except for the hot chick in the red whimp car.
Oh yea lack of oil circulation is my guess. |
Lo-Fi Version | Time is now: 15th May 2024 - 11:03 AM |
