right side not working well |
ruddyboys |
Dec 11 2006, 04:43 PM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
I have dual dell's, the car idles rough, but runs. I noticed the left side exhaust very hot and the right warm. I can see fuel going in, and when I put my hand over the top right throut the idle goes up. (IMG:style_emoticons/default/ar15.gif) Whe I remove my hand I can see sparks deep in the throat and the left side carbs backfire a little. So I have fuel and I have spark what can I look into. (IMG:style_emoticons/default/headbang.gif)
Dec 11 2006, 05:22 PM
I have dual dell's, the car idles rough, but runs. I noticed the left side exhaust very hot and the right warm. I can see fuel going in, and when I put my hand over the top right throut the idle goes up. (IMG:style_emoticons/default/ar15.gif) Whe I remove my hand I can see sparks deep in the throat and the left side carbs backfire a little. So I have fuel and I have spark what can I look into. (IMG:style_emoticons/default/headbang.gif) ok, let me get this straight ... you see sparks when you look down your carbs? (IMG:style_emoticons/default/confused24.gif) sounds like it's time for a valve adjustment ... the "spark" thing should happen when the valves are closed. meaning, you shouldn't be able to look down your carb and see any sparks ... (IMG:style_emoticons/default/smash.gif) Andy |
Twystd1 |
Dec 11 2006, 05:28 PM
Ditto,
Tight valve. You can't set your carbs until you have done a COMPLETE tune up toyour engine... Else you will chase your tail forever. Set valves first. Then point adjust (if you have them) (use new points please) Then timing. Then set the carbs up to both open at the same time and the same amount when the throttle cable is pulled. THEN you sync the carbs. In that order. STOP... Until you have done the above. And reprt back to us with what has transpired. Thats what I would do in your position... Cheers and Merry Christmas..!!!!!! C |
Lo-Fi Version | Time is now: 13th May 2024 - 11:41 PM |
