Trailing arm castle nut, Tools for removal? |
Doug Leggins |
Nov 16 2003, 07:48 PM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
I am trying to disassemble the rear trailing arm and replace the wheel bearing. I have tried the set up in the pic and cannot get the castle nut to budge.
Tomorrow I'll buy a 30mm socket and then try my 1/2" drive breaker bar. Will likely add a cheater bar to get even more force on the nut. (hydraulic jack handles work great for cheater bars) What have you used to remove the castle nut? Attached image(s) |
Nov 16 2003, 07:55 PM
Resident German Group: Admin Posts: 41,625 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Doug Leggins @ Nov 16 2003, 05:48 PM) What have you used to remove the castle nut? air ... |
J P Stein |
Nov 16 2003, 07:56 PM
Big old cheater bar, half drive, 30mm socket...or a STOUT impact wrench. I leave the arm on the car till that sucker is loose..... as you have it, the impact wrench is the hot set-up...unless you like to wrestle alligators. (IMG:style_emoticons/default/laugh.gif)
ss6 |
fun city... Group: Members Posts: 261 Joined: 2-February 03 From: Western Connecticut Member No.: 221 |
Best thing to use is an air driven impact wrench, something I don't have. Wound up taking the trailing arm AND my 30mm socket down to a nearby gas station / service center, and asked them to give it a try; they had it apart faster than I could get the other one out of the trunk, and didn't charge me a dime for the trouble.
Doug Leggins |
Nov 16 2003, 08:14 PM
I've wanted an impact wrench for quite a while.
I thought that it would be the best tool for the job. I just might be the owner of a new impact wrench tomorrow (IMG:style_emoticons/default/clap56.gif) |
nyum96 |
Nov 16 2003, 08:19 PM
Member Group: Members Posts: 75 Joined: 27-September 03 From: Roswell, GA Member No.: 1,200 |
Did that 3 days ago! 30mm and air for me. If you havent done the replacement yet, deep freeze the bearings and hub. Goes on easier and faster when putting it all back together! I also used axle and castle nut to seat the hub completely on the bearing. Good times. Its not the cleanest job! Good luck!
Barry |
Qarl |
Nov 16 2003, 08:22 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Another trick.... HEAT the castle nut with a propane torch until it is glowing and then try the impact wrench.
I had a 400 ft/lb torque air impact wrench that wouldn't budge the nut... then I heated it and tried a few times and it spin off! |
Jeroen |
Nov 16 2003, 09:05 PM
Breaker/cheater bar works just fine (even if you have the arms off the car), but if you need an excuse to buy new tools: YOU NEED AN IMPACT WRENCH (IMG:style_emoticons/default/biggrin.gif)
cheers, Jeroen |
Aaron Cox |
Nov 16 2003, 09:13 PM
do i smell a classic thread????? (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 9th May 2024 - 07:39 AM |
