Rear bushings, removal/replacement - How? |
Doug Leggins |
Nov 16 2003, 08:03 PM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
I am considering replacing the rear bushings while I have the trailing arms out. It is not intuitive to me how to remove the existing bushings. It doesn't look like they can be disassembled. (IMG:style_emoticons/default/confused24.gif)
Studs on both ends. nothing to put a wrench on. What am I missing? The factory manuals indicate that the rear bushings are not replaceable. I know better - I know that some of you have done this. I've searched for references on how to disassemble/ reassemble the rear trailing arm bushings but could not find enough info to figure it out. (IMG:style_emoticons/default/headbang.gif) Need some help! How are the rear bushings removed/reinstalled? Attached image(s) |
Doug Leggins |
Nov 16 2003, 08:07 PM
I just don't see how to get this off/out - Puzzled
Attached image(s) |
r_towle |
Nov 16 2003, 08:13 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
FIRE. (Insert pyro smily face here)
Jeroen |
Nov 16 2003, 08:15 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Go to a shop and have the threaded shafts pressed out
cheers, Jeroen |
Qarl |
Nov 16 2003, 08:26 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I started with the old torch approach and after five minutes of breathing the carinogenic fumes, I stopped, and brought it to my shop and they pressed them out in a few minutes.
J P Stein |
Nov 16 2003, 10:07 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
If they all look that good, leave them alone.....other wise FIRE, cut the flanges off with a utility knife first. Karl's problem is he does all this stuff in his living room.....excuse me....parts storage room. It don't look like much living goes on in there. (IMG:style_emoticons/default/laugh.gif)
markb |
Nov 16 2003, 10:22 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
QUOTE(Jeroen @ Nov 16 2003, 06:15 PM) Go to a shop and have the threaded shafts pressed out cheers, Jeroen (IMG:style_emoticons/default/agree.gif) |
J P Stein |
Nov 16 2003, 10:30 PM
Let me rephrase that.
Real men use fire. Candyasses take their problems to someone else. (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) |
Jeroen |
Nov 17 2003, 07:32 AM
QUOTE(J P Stein @ Nov 17 2003, 06:30 AM) Real men use fire...Candyasses take their problems to someone else Yep, you can always choose the JP-Route... (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) and (IMG:style_emoticons/default/smash.gif) some more If the part breaks, some additional (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) may be needed (IMG:style_emoticons/default/wink.gif) cheers, Jeroen |
Jeffs9146 |
Nov 17 2003, 09:35 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Does anyone have a source for stock ones? I will go with Mikes if they are easier to install!
Jeff |
fiid |
Nov 17 2003, 11:07 AM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
AFAIK - the stock ones are no longer available. There are Weltmeister plastic replacement bushings, or you can go with Muellers roller bearings.
I going the mueller route. Fiid. |
Mueller |
Nov 17 2003, 11:12 AM
Jeff,
I was under the impression that the only way to get the rubber bushings new is a brand new trailing arm (same deal with the front a-arms) I currently have at least a 2 week lead time for my rear bearings (unless Scott Spencer will sell you his uninstalled kit I have sitting on my work bench) (only one US distributor for the needle bearings and I already bought all they had in stock -ouch- ) |
Jeffs9146 |
Nov 17 2003, 01:05 PM
How much for the set and how hard is the install?
QUOTE I currently have at least a 2 week lead time for my rear bearings (unless Scott Spencer will sell you his uninstalled kit I have sitting on my work bench) Scott, are you still going to pick those up? Jeff |
Brad Roberts |
Nov 17 2003, 01:19 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
I need another set Mueller. The 3.0 conversion car owner wants all new suspension with the roller setup. I may use the one from "Blackie" just to buy you some time.
B |
Brad Roberts |
Nov 17 2003, 01:21 PM
Oh.. Doug.
Press them out. It takes HALF the time compared to the burn method. Real men use the proper tools. And.. Weltmeister STREET bushings are a decent replacement IF you dont want roller. They dont stick as bad and creak less than the hard RACE bushings. B |
J P Stein |
Nov 17 2003, 01:52 PM
QUOTE(Brad Roberts @ Nov 17 2003, 11:21 AM) Real men use the proper tools. Like engine test stands? (IMG:style_emoticons/default/laugh.gif) |
Pnambic |
Nov 17 2003, 02:22 PM
Honk if you like obscene gestures! Group: Members Posts: 914 Joined: 9-April 03 From: Atlanta, GA Member No.: 546 Region Association: South East States |
Brad Roberts |
Nov 17 2003, 02:25 PM
That was Britain. I dont have a test stand to fire off 912 engines.
B |
J P Stein |
Nov 17 2003, 02:32 PM
What we need here is a "tongue in cheek" smiley.
90% of my posts would have one of these. I don't take myself seriously.....there's no reason anyone else should (IMG:style_emoticons/default/laugh.gif) |
Brad Roberts |
Nov 17 2003, 02:34 PM
We also need a redneck smilie. For those times that we do fire off engine on a pallet.
I fired off a SBC 350 last year on one of those tiny V8 shipping stands. B |
Lo-Fi Version | Time is now: 19th May 2024 - 12:21 PM |
