Another stereo Q. Don't want to drain the battery, Do I need a switch? |
Hammy |
Dec 31 2006, 12:42 AM
I have my stereo wired so that it's always on (power and ign. both on constant power, fuse 12), regardless of ignition on or not.
When I turn the car off, I turn the stereo off by hand. Is there a possibility that from the way I have it wired I can drain the battery when parked? I'd hate to walk out to my car only to find a dead battery. Might I need to install a switch on the "ignition/switched power" wire? Or am I good? |
McMark |
Dec 31 2006, 01:01 AM
I think in most cases you'll be fine. Do you have a MultiMeter? You can test the amperage being drawn when the car & stereo are off. That'll let you know if you're in 'danger' of a dead battery.
computers4kids |
Dec 31 2006, 01:08 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
Twystd1 |
Dec 31 2006, 01:12 AM
Did you wire that up that way on purpose?
To run the stereo with the key off? C |
Hammy |
Dec 31 2006, 04:27 AM
Did you wire that up that way on purpose? To run the stereo with the key off? C Yes I wired it that way on purpose. Couple reasons for that: Our other cars have it so that when the ignition is off, stereo stays on until door is opened. Just feels more comfortable to me I sometimes sit with the car off and stereo on. Not for long periods of time though. Plus it's a good reminder to me to take the face plate off. There's an auto beep thing, but it ain't enough for me. I don't have an amp (yet) Mark, I have a multimeter. Where am I to test the amperage drain at? |
McMark |
Dec 31 2006, 11:13 AM
Turn off the car, turn off the stereo, pull off the + or - battery cable, connect one lead of the multimeter to the battery post and the other end of the lead to the battery cable end. What you are doing there is making all the electricity run through the meter so the meter can count/measure how much is flowing with everything turned off.
Twystd1 |
Dec 31 2006, 09:09 PM
FYI:
I hope you have a meter that can handle 8-10 amps input or more... Else your gunna blow up your meter. Or at least cook a fuse. Most meters are set up for Milliamp... Not amps. Cheers, C |
McMark |
Dec 31 2006, 09:18 PM
I hope his system isn't pulling 8-10 amps turned off.
Twystd1 |
Dec 31 2006, 09:24 PM
My bad Mark..........
I thought you were talking about between the head unit and the power lead. I just re-read the post... DUhhhhh Brain fart...... Cheers and thanks for the clarity.... Clayton |
McMark |
Dec 31 2006, 09:26 PM
Lo-Fi Version | Time is now: 14th May 2024 - 09:02 PM |
