Rear brake rotor removal, Castle nut |
1.8914 |
Mar 10 2007, 05:47 PM
Newbie Group: Members Posts: 25 Joined: 16-September 04 From: Stillwater, OK Member No.: 2,770 |
Hi guys...trying to get a wheel bearing and brake job done on my 74. Is the castle nut holding on the stub axle supposed to be super tight or am I missing something? I've never had one put up this much of a fight but never have done a bearing/cv replacement either.
Thanks! - Jeremy |
davep |
Mar 10 2007, 05:58 PM
914 Historian Group: Benefactors Posts: 5,144 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I have a couple that I have not been able to remove. I guess they just need more heat and a bigger impact gun.
Bigbohr |
Mar 10 2007, 06:03 PM
Superlurker Group: Members Posts: 224 Joined: 19-September 03 From: Houston, TX Member No.: 1,176 |
Had one that I couldn't get off either. Had to get help of an impact wrench to get it loose. Even then the darn thing still put up a (very brief) fight before letting go.
So.Cal.914 |
Mar 10 2007, 06:09 PM
I have a couple that I have not been able to remove. I guess they just need more heat and a bigger impact gun. (IMG:style_emoticons/default/agree.gif) Or a breaker bar and a long piece of pipe and lots of heat, a ox /acetylene or even mapp gas torch. |
Twystd1 |
Mar 10 2007, 06:24 PM
You don't want to know... really..... Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
I keep an old 5 foot long piece of 2 inch galv pipe in my garage for just such occasion.
With a quality breaker bar and a propane torch. I can dam near flip a car over. Go Home Depot and buy a stick of galv pipe. get a short one and long one. You will have cheater bars for life. And the short bar works bitchin for rolling fenders.....!!!! C |
Dave_Darling |
Mar 10 2007, 06:29 PM
Is the castle nut holding on the rotor supposed to be super tight or am I missing something? I dunno, it's "only" spec'ed to about 250 lb-ft. Plus however much it takes to overcome the rust that holds the nut and stub together. Plus however much it takes to break the cotter pin... (D'OH!) --DD |
Aaron Cox |
Mar 10 2007, 06:39 PM
make sure you remove the cotter pin first (IMG:style_emoticons/default/chairfall.gif)
recently i was taking apart some 68 911 arms....after breaking both cotter pins off... and tapping em out... the nut fought my impact for a while. soak in wd40.... came back... worked great (IMG:style_emoticons/default/smile.gif) |
jr91472 |
Mar 10 2007, 08:14 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
wheaties....eat your wheaties.... (IMG:style_emoticons/default/biggrin.gif)
Sorry....seriously solvents and physics are your friends (aka PB Blaster and a long breaker bar). I slipped the 4 foot handle off my floor jack over my 2 ft breaker bar to increase the leverage. Oh and chalk the wheels - I pretty much rolled my car out of the garage before mine gave it up. good luck |
1.8914 |
Mar 10 2007, 09:32 PM
Hi guys...thanks for the help. Didn't need to worry about the cotter pin as whomever was in there last didn't put it back in! I stopped to watch some tv and drink a beer (IMG:style_emoticons/default/beerchug.gif) with the neighbor as it soaked in liquid wrench. It broke loose right away after that.
On to the bearing removal!!! (IMG:style_emoticons/default/biggrin.gif) |
Joe Bob |
Mar 10 2007, 09:36 PM
I just had the worst ever nut on the 58....I broke a 1/2 breaker bar when using my 3 foot cheater bar. I used heat (MAPP AND Propane) and PB Blaster.
I ended up buying a 3/4 breaker bar with the afore mentioned cheater and a 1 7/16 six point socket.....when it let go it sounded like a .357 going off.... |
Lo-Fi Version | Time is now: 20th May 2024 - 08:15 AM |
