brp914 |
Unregistered ![]() |
1. how many 0.090" thrust races are needed? seems to me you need 4 per A-arm. I have 4 total.
2. how do you seal the A-arms against dirt/water ingress? |
skline |
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California ![]() |
If this is for your suspension, you need two per side and then you put the washer and O-ring on and seal it with silicone. Did you read the directions? (IMG:style_emoticons/default/poke.gif)
db9146 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None ![]() ![]() |
There are instructions? I purchased some remaining components from someone who used to make them and sell them on the board but I never got any instructions.
Twystd1 |
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,515 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 ![]() |
Scott... hows the new car doing????
Is Brando there yet??? C |
brp914 |
QUOTE If this is for your suspension, you need two per side and then you put the washer and O-ring on and seal it with silicone. Did you read the directions? the instructions say put on a washer, then a thrust bearing, then another washer (without saying whether this is the front or rear of the A-arm). ok, fine. but I have 4 thrust bearings and 4 thrust washers. So I have 2 too many bearings, or 4 too few washers. also, no orings. |
skline |
I sent you a PM.
I have a PDF file with the instructions on how to put them in. (IMG:style_emoticons/default/smile.gif) |
skline |
Lo-Fi Version | Time is now: 30th June 2025 - 10:19 PM |
