sbc carb choice, holley or edelbrock |
pffft |
Apr 9 2007, 02:20 PM
Member Group: Members Posts: 189 Joined: 18-January 05 From: sierra foothills Member No.: 3,465 |
My pockets are not deep enough for FI right now,
so i am limited to carbs. When I went to bolt the oldish holley that came with my motor on this weekend, I discovered it won't fit. I had never removed the lifting plate from the manifold before, but when I did it was obvious this was a no go, I am guessing this is an early carter manifold and the holley has a much bigger base. So I'm gonna go ahead and get a new manifold, newer technology and save some weight while I'm at it. But since I'm replacing the manifold I started wondering about the unknown condition of the carb (I think it is a vacumm secondary 600) So, any suggestions on whether to go Edebrock/Carter or Holley if I do replace it? I've had a couple holleys before, but not in 30 (gasp) years. Hyd lifter 327 with (afaik) stock internals. If my new tranny comes through I will not be as worried about keeping it mild, but for now it is going in front of a stock 901. patrick |
Lo-Fi Version | Time is now: 27th May 2024 - 08:59 PM |
