No gass to dell |
No gass to dell |
ruddyboys |
May 2 2007, 01:40 PM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
It seems I am not getting gas to my Dell 36 DRLA. I took the carb apart to clean it, it had a lot of ashlike crud inside. After cleanning the jets and passages with carb cleaner and a little compressed air I put it all back together and reinstalled. The car wont start, so I go and look down the throat and when I open the throtal no gas. The other carb is fine. In the red circled jet I get a little trinkle of gass, the green circled jet, not a drop. When I pullout the red circled jet it is wet with gas, the green dry. I cleaned the jets with carb cleaner and they are clear. What could be cloged if this is the problem, Oh yes the butterfly valve does open.
Lo-Fi Version | Time is now: 25th May 2024 - 06:22 PM |
