How to remove anodizing from Fuch's? |
Allan |
May 14 2007, 02:13 PM
Anyone have a decent method for removing anodizing from rims.
I think I'm just going to polish the lips and have the centers painted to match the car. |
So.Cal.914 |
May 14 2007, 02:15 PM
Needs to be sanded smooth.
Ferg |
May 14 2007, 02:22 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
I've used easy off oven cleaner in the past on anodized bike parts.
Ferg |
TravisNeff |
I heard oven cleaner will remove anodizing
So.Cal.914 |
May 14 2007, 02:30 PM
It is an electrochemical process that thickens and toughens the naturally occurring protective oxide. The resulting finish, depending on the process, is the second hardest substance known to man, second only to the diamond. The anodic coating is part of the metal, but has a porous structure which allows secondary infusions, (i.e. organic and inorganic coloring, lubricity aids, etc.)
There is a cheap spray 'anodizing' but real anodizing is not going to come off with oven cleaner. Sorry not that easy. (IMG:style_emoticons/default/sad.gif) |
Eric_Shea |
May 14 2007, 02:55 PM
Have them de-anodized... it's cheap.
Any anodizer can do it. Best by far. |
Aaron Cox |
May 14 2007, 03:52 PM
you sure your fakes are anodized?
none of mine were.... |
736conver |
May 14 2007, 04:33 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
QUOTE oven cleaner. Sorry not that easy BTDT I heard stories of oven cleaner and so I tried it. Didnt work well at all. Ended up getting them de-anodized by a local company. Didnt cost much if I remember. |
iamchappy |
May 14 2007, 04:35 PM
Lye
Twystd1 |
May 14 2007, 04:40 PM
Like the inimitable Aaron said.
Fake Fuchs aren't anodized that I have ever seen. And I think I have owned all 3 brands of fakes at one time or another. Conversely.... Maybe someone had it done on your wheels. I dunno. Heres a little trick that Eric taught me. All my friends are into this now. it works very fast and has a very LONG and profound effect on the metal. The easiest way to remove the anodizing is with the SEAL oil or NAUGA oil. Same stuff they make window seals out of in Germany or Naugahyde in Russia. It's a shame they have to kill so many Nauhgas and Seals to make the stuff. But what the hell... Our cars come first. You apply the Seal or Nauhga oil to the metal and let it sit in the sun for 3 days. NO MORE THAN THAT. Then you cover the wheels with some kind of human or animal feces for 1 more day. Feces must be fresh and pliable. Old shit doesn't work as well. Then you typically start to scrape the dung off with steel wool. DON'T USE GLOVES!!!! The glove oil will interfere with the Seal or Nauhga oil and leave glove prints on the metal. Then you bake the wheels in the oven for 3 hours at 450 degrees. And rinse them off with hot water. I suggest using your Jacuzzi as the chlorine and urine helps to remove the baked on feces. Then polish to a golden hue using baby diapers. Preferably used ones as they leave a better patina...!!!!! So there you go Allan. And thanks to Eric for teaching me all this stuff. Cheers and good luck with this new removal process. Regards, Aaron Cox. |
So.Cal.914 |
May 14 2007, 05:06 PM
(IMG:style_emoticons/default/av-943.gif) Now I know how...Thanks Aaron.
brant |
May 14 2007, 05:08 PM
I've personally strip the anodizing off of all of my 15x7real fuchs.
it will work oven cleaner will work easier than sand paper. buy the heavy duty (easy off - yellow can) Attached thumbnail(s) |
Aaron Cox |
May 14 2007, 05:15 PM
what a tool..... everyone knows nauga doesnt have an H.......
i call imposter! (IMG:http://lowellfox.com/linkspage/stanleyG/NaugaWeb.jpg) |
Twystd1 |
May 14 2007, 05:32 PM
Dam... OWNED again...
AAArrrGGGhhhhhh... C |
Aaron Cox |
May 14 2007, 05:34 PM
go find my stub pipes....please?
Twystd1 |
May 14 2007, 05:44 PM
Already sent BJ to do that for ya... Brudder...!!!!
CCC |
bigkensteele |
May 14 2007, 11:43 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
I am going to bead blast mine, then paint an clearcoat for the RSR look. They come out more or less frosted, which looks nice. There are a few threads on Pelican that I would find and paste here if I were not lazy.
So.Cal.914 |
May 15 2007, 01:58 AM
Anodize Remover 16oz #797
Qty: Price: $12.00 Click Image for larger picture. Shipping: CLICK HERE FOR SHIPPING COST Mix with warm water to make a solution to strip the anodized coating from aluminum trip. This compound leaves a satin finish that can be buffed to a mirror finish with a soft buff and #739 compound. http://www.jestcoproducts.com/buffing_compounds2.html From what I read it removes a thin layer of metal too, as does the lye. |
machina |
May 15 2007, 06:45 AM
Lye yes, you have to get the old style cleaner that has lye as the active ingredient. most on the shelves are the new safer kind. i only did some small parts from my bike but that stuff definitely works. I'll bet that bottle of "anodize remover" is just a bottle of lye. just be careful, its nasty stuff. |
woobn8r |
May 15 2007, 07:47 AM
Senior Member Group: Members Posts: 607 Joined: 7-January 07 From: Newmarket, Ontario, Canada Member No.: 7,435 Region Association: None |
I am going to bead blast mine, then paint an clearcoat for the RSR look. They come out more or less frosted, which looks nice. (IMG:style_emoticons/default/agree.gif) I have done several sets of original Fuchs by bead (media) blasting. Does a great job and accepts paint very well.... |
Lo-Fi Version | Time is now: 14th May 2024 - 06:05 AM |
