rennshift help...., who has it? |
jonferns |
May 26 2007, 08:05 PM
so....rennshift....heard its a good mod to do (to improve the very sloppy shifting)....so, does anyone have it, how was the installation, and what does it improve....would really appreciate some info from someone who has it....thanks alot in advance.... ---JON (IMG:style_emoticons/default/biggrin.gif)
JWest |
May 26 2007, 09:13 PM
I have a few - it's a good mod. (IMG:style_emoticons/default/biggrin.gif)
ConeDodger |
May 26 2007, 09:23 PM
Apex killer! Group: Members Posts: 23,586 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
so....rennshift....heard its a good mod to do (to improve the very sloppy shifting)....so, does anyone have it, how was the installation, and what does it improve....would really appreciate some info from someone who has it....thanks alot in advance.... ---JON (IMG:style_emoticons/default/biggrin.gif) The post below your original is a little joke you may not get Jon. James Adams is the designer, manufacturer, and owner of JWest Engineering and may be biased. I have the Rennshifter in my silver car. I also have several other JWest products. My 901 was pretty bad when I got my car. After all of the bushings in the shift mechanicals were changed out improved dramatically but the biggest improvement was the Rennshifter. A 901 shouldn't shift this good. Put it on your list and after you have good brakes, good running engine, then get it. James sells several other things of value too when you get to his website. |
TimT |
May 26 2007, 09:24 PM
Rennshift is money well spent
May 26 2007, 09:51 PM
to improve the very sloppy shifting NO if you got sloppy shifting, you got other problems! don't try to use the rennshift as a cure for your sloppy shifting. FIX your shifter problem first. THEN improve your shifting experience with a rennshifter. the stock 914 shifter setup can be made to shift without slop ... (IMG:style_emoticons/default/bye1.gif) Andy (proud owner of a rennshifter) |
Dr Evil |
May 26 2007, 11:31 PM
(IMG:style_emoticons/default/agree.gif) replace all of your shift bushings first.
jonferns |
May 27 2007, 08:07 AM
yea...i have the shift bushings here, to replace, probably today....--JON
jonferns |
May 27 2007, 11:54 AM
so...what will it take to install, as far as time goes...and also, what needs to be taken out??? any cutting/welding??? thanks alot ---JON
Dr Evil |
May 27 2007, 12:00 PM
Bolts right in, no problem. You just need to adjust it.
pete-stevers |
May 27 2007, 12:15 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
fix up slop first...then get a shifter...
for even more improvement! |
john rogers |
May 27 2007, 02:46 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
As noted previously, replace all the bushings, then get one of the middle coupler replacements, either the setup James sells or someone elses and then install the Rennshift. Once it is adjusted it will shift like magic, my race car sure does. I can shift into 1st gear at 20 MPH when I race in Mexico at the tight street races and it is great to have!
Lo-Fi Version | Time is now: 15th May 2024 - 12:26 AM |
