| Jake Raby |
Jul 16 2007, 06:37 AM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
OK, finally got a few minutes to share some roller cam info....
![]() Roller cams are the major factor that keeps the VW pushrod driven engine from being made more modern. All of todays modern pushrod engines use roller cams and lifters to provide valve actuation, due to this these engines can run on oils that do not have as much zinc and phosphorous contant and this is a huge factor that is driving all my engines to the roller technology. Roller cams provide the following: - More power than any flat tappet cam of similar characteristcs, due primarily to faster opening events. - Less friction than a flat tappet as the roller wheel actually "rolls" on the cam lobe instead of depending on lobe tapers and lifter crown radii to spin the lifter (HUGE) -The use of roller cams and lifters allows much small lift and duration numbers to be used to gain the same net power as a much larger flat tappet cam, this means better idle, better EFI system compatability due to a stronger and more stable manifold pressure. It's no secret that we are doing the roller lifter development to meet two main objectives, the first being better compatibility with modern oils and the second to make more power. Roller equipped engines have serious throttle response compared to flat tappet cams and they also have serious torque curves due to the extreme chamber filling at lower lifts because of the ramp speed of the cam. The friction reduction with these cams and lifters is a huge benefit, the way our roller lifters are designed there is virtually nothing to wear out as the engine gains age. The use of an 8620 tool steel camshaft blank coupled to the rioller wheel that is made from another grade of tool steel (for compatability) results in two components that are well lubricated, resistant to wear and resistant to failure either on the street or on the track. My emphasis with this development has been 13 months in the making, the first 5 months was the simplest, basically sourcing materials, designing lobes and having the cam blanks made up from scratch. After this point the project was stalled due to one company going out of business, my schedule and all sorts of tooling issues with the case alignment tools we designed to install the bushings. The last six months has been full of ups and downs but last week we finally got the bushings installed the way that made me happy and with the latest revision to the toolimng is fairly simple for us. This week we will be doing tests in the simulation device and then tearing down to measure wear, bushing aligment and etc. What will follow is a series of 4 different test engines being built with both roller and flat tappet cams for comparisons in power and tuning. After these four engines are completed this technology will be the standard here with all of my "Performer" based engines using the technology by mid 2008 at the latest. I'll close by saying this development is being made primarily for STREET engines, not race engines! Most every racing venue that exists for the 914 has rules that do not allow for roller camshafts to be employed- when something is made illegal by a racing body you can bet that it really works and gives it's users a huge edge- Here are some detailed pics, I have shared more similar pics over at my forums in the R&D section. ![]() Here are some of the bushing alignment tools used to check bushing install to ensure the roller lifters are going to be truly perpendicular to the camshaft ![]() This is a digital plot from our cam profiler that clearly shows the differences between a roller and flat tappet cam that have the same .050 duration values and similar lobe lift, note how much wider and flatter the 9900 series camshaft is, this and all 9900 series cams are rollers. ![]() So, there ya have it, couple these to a pair of porkies heads and 300 REAL HP was never made so easy or reliable before. (IMG:style_emoticons/default/boldblue.gif) |
Jake Raby Some roller cam detailed info (and new pics) Jul 16 2007, 06:37 AM
Jake Raby Oops, forgot a pic or two of the billet rocker arm... Jul 16 2007, 06:56 AM
Jake Raby Now for some pics of the porkies heads that will a... Jul 16 2007, 09:34 AM
grantsfo
The six cylinder guys really won't be liking... Jul 16 2007, 01:13 PM
Bleyseng Way cool Jake, I have stated a rollercam fund for ... Jul 16 2007, 10:01 AM
Jake Raby 160HP from a daily driver 2056 is a reality... I a... Jul 16 2007, 10:11 AM
greybeard50
160HP from a daily driver 2056 is a reality... I ... Jul 16 2007, 02:52 PM
914nerd :drooley:
When are these going to be out and avai... Jul 16 2007, 10:16 AM
Jake Raby These are going to be only available in complete e... Jul 16 2007, 11:05 AM
Thomas J Bliznik
These are going to be only available in complete ... Jul 16 2007, 02:10 PM
Bleyseng
These are going to be only available in complete... Jul 16 2007, 02:15 PM
Thomas J Bliznik
[quote name='Thomas J Bliznik' post='924041' date... Jul 16 2007, 02:27 PM
McMark I am so excited about all these new developments. ... Jul 16 2007, 12:52 PM
DNHunt Man Jake this is worse than being 3years old with ... Jul 16 2007, 01:01 PM
Jake Raby Grant, we have never really had an adventure go ba... Jul 16 2007, 01:32 PM
grantsfo
Grant, we have never really had an adventure go b... Jul 16 2007, 06:39 PM
SirAndy I'll be the first to let you know when someone... Jul 16 2007, 06:48 PM
grantsfo
I'll be the first to let you know when someon... Jul 16 2007, 06:58 PM
I'd run against Andrew on the track any day
... Jul 16 2007, 07:30 PM
grantsfo
I'd run against Andrew on the track any day ... Jul 16 2007, 07:43 PM
Bleyseng
[quote name='SirAndy' post='924189' date='Jul 16 ... Jul 16 2007, 07:33 PM
grantsfo
When did Jake just become a "bunch of talk... Jul 16 2007, 07:49 PM
Bleyseng
When did Jake just become a "bunch of talk... Jul 17 2007, 09:40 AM
ChrisNPDrider :clap:
For PCA racing the upgrade would probably ... Jul 16 2007, 01:34 PM
Jake Raby Yep, it would be worth taking the points hit to in... Jul 16 2007, 01:41 PM
Trevorg7 Sorry - pet peeve of mine
If people could care ... Jul 16 2007, 01:49 PM
Bleyseng It does create another option for 914's and gu... Jul 16 2007, 01:55 PM
Jake Raby Rollers for the westy are no issue.. I am working ... Jul 16 2007, 02:00 PM
smontanaro Silly question I know, but just where are the roll... Jul 16 2007, 02:26 PM
Bleyseng
Silly question I know, but just where are the rol... Jul 16 2007, 02:32 PM
Jake Raby Tom, we have not even been concerned with sales at... Jul 16 2007, 02:36 PM
cuca914
Tom, we have not even been concerned with sales a... Jul 16 2007, 03:00 PM
Thomas J Bliznik
Tom, we have not even been concerned with sales ... Jul 16 2007, 03:17 PM
Jake Raby We'll always be keeping the daily driver combo... Jul 16 2007, 02:58 PM
McMark You definitely shouldn't wait, there will alwa... Jul 16 2007, 03:13 PM
cuca914
You definitely shouldn't wait, there will alw... Jul 16 2007, 03:19 PM
Jake Raby Don't wait on me... None of this craziness may... Jul 16 2007, 03:18 PM
toon1
[quote name='cuca914' post='924066' date='Jul 16 ... Jul 16 2007, 03:22 PM
Thomas J Bliznik
[quote name='cuca914' post='924066' date='Jul 16... Jul 16 2007, 03:25 PM
Jake Raby #3 will get you going now- if you have and want to... Jul 16 2007, 03:31 PM
cuca914
#3 will get you going now- if you have and want t... Jul 16 2007, 03:41 PM
Jake Raby Yes, we are still selling it, if you need the 9550... Jul 16 2007, 03:43 PM
toon1
#3 will get you going now- if you have and want t... Jul 16 2007, 05:53 PM
Jake Raby Two injectors per runner/cylinder.. One down low b... Jul 16 2007, 06:05 PM
crash914 OMG!!
You are really pushing the envelope... Jul 16 2007, 06:23 PM
Jake Raby Individual runners only, a plenum that would feed ... Jul 16 2007, 06:29 PM
Jake Raby Thanks for the reality check Grant, there always h... Jul 16 2007, 06:44 PM
grantsfo
Thanks for the reality check Grant, there always ... Jul 16 2007, 06:51 PM
Jake Raby
I'm sure your customers here appreciate yo... Jul 16 2007, 07:03 PM
Dan (Almaden Valley) I have a nicely built 2056 with the Raby 9550 cam ... Jul 16 2007, 06:54 PM
grantsfo
I have a nicely built 2056 with the Raby 9550 cam... Jul 16 2007, 07:00 PM
Dan (Almaden Valley) it all takes developement....Jake is willing to pu... Jul 16 2007, 07:19 PM
Jake Raby Randal's car will be fast and he is working th... Jul 16 2007, 07:23 PM
grantsfo
Randal's car will be fast and he is working t... Jul 16 2007, 07:54 PM
Jake Raby Our car is built- we tested it at a circle track l... Jul 16 2007, 07:40 PM
Jake Raby We are not shooting for just power, a HUGE reason ... Jul 16 2007, 07:52 PM
sww914
Thanks for the reality check Grant, there always ... Jul 16 2007, 08:54 PM
Jake Raby And all I need is the right person and the right c... Jul 16 2007, 09:07 PM
grantsfo
And all I need is the right person and the right ... Jul 16 2007, 10:22 PM
Dan (Almaden Valley) I would be happy to use my car as a test mule for ... Jul 16 2007, 09:12 PM
Joe Ricard
I would be happy to use my car as a test mule for... Jul 16 2007, 09:27 PM
Joe Ricard Seems like Grant has forgotten to take his Meds to... Jul 16 2007, 09:13 PM
grantsfo
Seems like Grant has forgotten to take his Meds t... Jul 16 2007, 10:09 PM
Jake Raby Dan,
I like your style and your attention to detai... Jul 16 2007, 09:21 PM
Dan,
I like your style and your attention to deta... Jul 16 2007, 11:01 PM
Jake Raby Ok, you find me, or I'll find you, one way or ... Jul 16 2007, 10:29 PM
grantsfo
Ok, you find me, or I'll find you, one way or... Jul 16 2007, 10:31 PM
grantsfo LOL! RPG = Raby Powered Grenade. Jul 16 2007, 10:30 PM
Jake Raby Yep, phone call works fine- I am here right now at... Jul 16 2007, 10:33 PM
grantsfo
Yep, phone call works fine- I am here right now a... Jul 16 2007, 10:46 PM
McMark :rotfl:
You guys are funny. Jul 16 2007, 10:42 PM
Jake Raby Cheap bastard. I don't know if cell phones acc... Jul 16 2007, 11:04 PM
Cheap bastard. I don't know if cell phones ac... Jul 16 2007, 11:07 PM
Jake Raby MS would work with the motorcycle T/B set up or a ... Jul 16 2007, 11:12 PM
MS would work with the motorcycle T/B set up or a... Jul 16 2007, 11:15 PM
Brando I'd love to be sponsored with a forced-inducti... Jul 16 2007, 11:23 PM
I'd love to be sponsored with a forced-induct... Jul 16 2007, 11:28 PM
grantsfo
I'd love to be sponsored with a forced-induc... Jul 17 2007, 12:17 AM
Jake Raby Grant and I both know that the big boys play in SC... Jul 17 2007, 12:36 AM
grantsfo
Grant and I both know that the big boys play in S... Jul 17 2007, 01:22 AM
gregrobbins Type IV powered car that whipped a bunch of sixes. Jul 17 2007, 12:47 AM
craig downs As the saying goes "when the green flag drops... Jul 17 2007, 01:10 AM
Jake Raby Morning is going great- talking to McMark about ro... Jul 17 2007, 01:25 AM
ChrisNPDrider
Morning is going great- talking to McMark about r... Jul 17 2007, 11:07 AM
ConeDodger
Morning is going great- talking to McMark about ... Jul 17 2007, 12:12 PM
grantsfo
Seems like they settled that 6 vs. 4 debate at Pa... Jul 17 2007, 01:22 PM
Joe Ricard Please take this to the Paddock
... Jul 17 2007, 11:42 AM
nebreitling valid point -- especially about the driver -- but ... Jul 17 2007, 12:19 PM
ConeDodger
valid point -- especially about the driver -- but... Jul 17 2007, 03:47 PM
Steve Thacker Sounds like a pissing contest to me. I always hear... Jul 17 2007, 12:53 PM
grantsfo
Sounds like a pissing contest to me. I always hea... Jul 17 2007, 01:33 PM
hwgunner Grant, just curious-- What are your best times fo... Jul 17 2007, 02:01 PM
Twystd1 THIS IS GREAT STUFF...!!!!!... Jul 17 2007, 02:35 PM
sww914 If you guys both show up at Laguna, Buttonwillow, ... Jul 17 2007, 03:01 PM
sww914 At Willow Springs I've seen the track surface ... Jul 17 2007, 03:55 PM
Joe Ricard You say that road Atlanta does not get hot?
Jum... Jul 17 2007, 04:06 PM
grantsfo
Ju... Jul 17 2007, 05:49 PM
Steve Thacker Grant talk the shit if you must. Step up and make ... Jul 17 2007, 05:18 PM
mike souza ok first off
Biggy,
Tupac,
stop with the east c... Jul 17 2007, 05:23 PM
McMark Grant, do you still have 4cyl mounts in your car? ... Jul 17 2007, 05:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:43 PM |
